Determining the recycle ratio in a PFR
  • Thread starter Thread starter MichelV
    Ratio
2 replies · 3K views
MichelV
For an irreversible first-order liquid-phase reaction (CA,0 = 10 mol/L) conversion is 90% in a plug flow reactor. If two-thirds of the stream leaving the reactor is recycled to the reactor entrance, and if the throughput to the whole reactor-recycle system is kept unchanged, what does this do to the concentration of reactant leaving the system?
For a first-order reaction where ##\epsilon_A = 0## without a recycle:
CA / CA,0 = e-k##\tau## (i)
For a first-order reaction where ##\epsilon_A = 0## with a recycle:
## k \tau = (R+1) ln \left[ \frac{C_{A,0} + R C_{A,f}} {(R+1) C_{A,f}}\right] ## (ii)
Rewriting equation (i) gives:
##k\tau = ln \left( \frac {C_{A,0}} {C_A} \right) = ln \left( \frac {10} {1} \right) = ln (10)##
And if I were to know the value of R i could fill in equation (ii) except for CA,f and combining equation (i) and (ii) would give me the opportunity to solve for CA,f and determine the conversion in the PFR with recycle to answer the question.
I think determining the value of R should have something to do with this line from the problem:
"If two-thirds of the stream leaving the reactor is recycled to the reactor entrance, and if the throughput to the whole reactor-recycle system is kept unchanged."
It's just that I don't really get what they mean by this. Could someone point me in the right direction?
Thanks a lot!
So for every m3 of feed (feeds to the whole system are the same in the original case and in the recyclce case) the recylce adds 2 m3 and sends the 3 m3 to the reactor input. At the output 2 m3 is recycled and 1 m3 is product.
You use symbols without explaining them and without differentiating them (##\tau, R##). What is ##\tau## and is it the same in both cases ?
Thanks a lot!
The way I read this is that the reactant concentration of the output is 10% that of the input. So draw a flow diagram and write the flow balance equation. Then solve for the concentration of the output.
