Determining the transfer function
2 replies · 3K views · last reply
grothem
Determine the transfer function between output x and input F for the following mass-spring system. (see attached image)
F=ma
Inertia, T = J [tex]\alpha[/tex]
Rotational Damper, T=B [tex]\omega[/tex]
Rotational Spring, T=K [tex]\theta[/tex]
I'm having trouble relating the rotational forces to F.
F=m [tex]\ddot{x}[/tex]
k so I guess the latex equations aren't coming out right.
but basically, T = J [tex]\ddot{[tex]\theta[/tex]}[/tex] + B[tex]\dot{[tex]\theta[/tex]}[/tex] + K [tex]\theta[/tex]
The sum of all forces, including inertial forces must equal zero, and I need to convert to the laplace domain to get X(s)/F(s), but how does T fit into that?
  • Mass-spring system diagram with a pulley of inertia J and radius R, a mass m with applied force F pointing down, and a spring k and damper b attached to the pulley's side; output x is marked at a fixed support.
You may want to consider making a free body diagram for each component. It should be seen that T=ma for starters.
F=ma
You have already your differential equation:
T = J [tex]\ddot{\theta} + B\dot{\theta} + K\theta[/tex]
Now apply the Laplace transform to obtain the transfer function in rotational variables:
[tex]\frac{\theta(s)}{T(s)}[/tex]
