Determining the velocity of sound in the air by the resonance method
The discussion focuses on measuring the velocity of sound in air using a tuning fork and a closed-end pipe. Two methods are proposed: the End Correction method, which applies a correction factor to the first resonant length based on tube diameter, and the Second Resonant Length method, which calculates the distance between two resonant lengths to determine wavelength. Key questions raised include identifying sources of measurement uncertainty, suitable tuning fork frequencies, predicting third resonance lengths, and the rationale behind not applying the end correction in the second method. The results from two different tube diameters show varying effective lengths and calculated velocities. The conversation emphasizes the need for participants to demonstrate effort in their inquiries to receive assistance.
mjdom
measure the velocity of sound in the air using tuning fork and a pipe closed at one end
method a: End Correction involves applying a correction factor to the first resonant length based on the diameter of the tube used.
method b: Second Resonant Length involves finding two successive resonant lengths of the air column within the pipe. The distance between these points represents half a wavelength of the resonance frequency.
equipment - two lengths of PVC tubing of 30mm and 50mm diameter
Le= L + 0.29d
wavelength of the sound = 2x (L2-L1)
questions i want to ask,,
- list the main source of measurement uncertainty
- what frequencies of tuning forks is more suitable
- predict third resonance length for each tuning fork used in method b
- what value you would expect in substracting the second resonant length from thr third resonant length?
- expain why the end correction factor is not applied in the second part of the investigation
- reason for measuring air temperature inside the pipe[/B]
diameter of tubes 50mm - first resonant length L (m) : 0.304 / effective length Le (m) : 0.318 / wavelength 4 x Le (m): 1.274 / velocity : 326.14
diameter of tubes 30mm - first resonant length L (m) : 0.33 / effective length Le (m) : 0.338 / wavelength 4 x Le (m): 1.354 / velocity : 346.14
fork 1 frequency : 256
i havnt got result for method 2...
Questions are not attempts at solutions. What are your thoughts on each of your questions? You need to show some effort before help can be given.
i know but to be honest i have no idea about this experiment.. can u give some examples? so i can get some idea
  • · Replies 33 ·
12K
