Diagonalizability and Invertibility
  • Thread starter Thread starter JG89
The discussion centers on the relationship between diagonalizability and invertibility of linear operators in finite-dimensional vector spaces. It is established that a linear operator T is invertible if and only if it has no zero eigenvalues. While diagonalizability implies the existence of n linearly independent eigenvectors, it does not guarantee invertibility unless all eigenvalues are non-zero. The zero transformation is specifically identified as non-invertible unless it operates in a trivial zero-dimensional space.
  • Understanding of linear operators and vector spaces
  • Knowledge of eigenvalues and eigenvectors
  • Familiarity with the rank-nullity theorem
  • Concept of diagonal matrices and their properties
  • Study the implications of the rank-nullity theorem in linear algebra
  • Explore the characteristics of diagonal matrices and their eigenvalues
  • Learn about the conditions for invertibility in linear transformations
  • Investigate the properties of zero transformations in vector spaces
Mathematicians, students of linear algebra, and anyone interested in the properties of linear operators and their applications in vector spaces.
JG89
Let T be a linear operator on an n-dimensional vector space V. Am I correct in saying that if T is diagonalizable then T is invertible? My reasoning is that if T is diagonalizable then there is an ordered basis of eigenvectors of T such that T's matrix representation is a diagonal matrix. Obviously the rank of the n*n diagonal matrix is n and so the rank of T is n. Now, from a well known theorem we have nullity(T) + rank(T) = dim(V), and since rank(T) = dim(V), we see that nullity(T) = 0, implying that T is both one-to-one and onto, and so T is invertible.
The rank of an n by n diagonal matrix is certainly not always n.
Diagonalizability is about having n linearly independent eigenvectors, and is nothing to do with invertibility. Invertibility is about eigenvalues.
Hmmm...a diagonal matrix has all non-diagonal entries as 0, and so each row has only one non-zero entry, this entry belonging to a column whose all other entries are 0, so how could one column of the diagonal matrix be written as a linear combination of the others, if you get what I mean? For example, say we have this 3*3 matrix:A 0 0
0 B 0
0 0 C
No column could ever be written as a linear combination of the others. It seems to me that this would be the case for all diagonal matrices.EDIT: It seems like what I am saying about diagonal matrices is true only if there is no zero entry on the principal diagonal. Since the diagonal entries of a diagonal matrix are its eigenvalues, then we could say that if no eigenvalue of T is zero then T is invertible. Is this correct?
I also have another question. I once learned that if T is a linear transformation from V to W (both finite dimensional vector spaces), then T is invertible if and only if dim(V) = dim(W). In the case that W = V, T is a linear operator and obviously we have dim(V) = dim(V). So does this imply that ALL linear operators are invertible? Intuitively it doesn't seem like the zero-transformation is invertible.
Yes, an nxn-matrix (no need for it to be diagonal) is invertible if and only if 0 is not an eigenvalue. This is easy to see from the definition of an eigenvalue.
No, this is wrong. If T is invertible, then dim(V)=dim(W), but the converse is false. The zero-map from V to W is invertible only in the trivial case dim(V)=dim(W)=0.
If the zero transformation is from V to V, then the matrix representation of that transformation would be an n*n matrix where every entry in the matrix is 0. So wouldn't the rank of the matrix be 0 since there are no linearly independent column vectors? If this is so, then how can the matrix be invertible if its rank is less than n? I thought an n*n matrix is invertible if and only if its rank is n.
n=0 in the case you're troubled by.
You probably forgot that W was supposed to be the image of T. (or maybe that T was supposed to be surjective)
Is my reasoning right here:
In the case that dim(V) = 0 then the empty-set spans V and so V is the zero-space (vector space consisting of only the zero vector). If V has only the zero-vector then obviously it has no eigenvectors of T in it, and so there are no eigenvalues. Thus 0 is not an eigenvalue of the zero transformation that acts on the zero-space and so this transformation is invertible.
Am I right in saying that since n = 0, its matrix representation doesn't exist? (I don't see how you can have a 0 by 0 matrix).
do you mean if invertible then no nonzero eigenvalue? Thanks.
No! He means exactly the opposite" "if invertible then no zero eigenvalue".
I suspect that was what you meant and just mistyped.
  • · Replies 23 ·
