Diagonalizing a metric by a coordinate transformation
The discussion revolves around the problem of diagonalizing a metric given by the expression ##{ds}^{2}=-{dt}^{2}+{dx}^{2}+2{a}^2(t)dxdy+{dz}^{2}## through a coordinate transformation. Participants are exploring the implications of various transformations and the dependencies of the functions involved.
  • Participants discuss the substitution of coordinates, particularly the transformation ##x=\tilde{x}+F(t,y)##, and the implications of this choice on the metric. There are questions about the dependency of the function ##F## on other coordinates and the complexity of the transformation. Some participants suggest trying different forms of transformations involving multiple functions for ##t, x, y, z##.
The discussion is ongoing, with participants sharing their attempts and questioning the validity of their approaches. Some have suggested alternative transformations and expressed uncertainty about the outcomes. There is no clear consensus on a straightforward solution, and various interpretations of the problem are being explored.
Participants note that the function ##a^2## is dependent on time ##t##, which complicates the diagonalization process. There are also mentions of the original metric lacking certain terms, leading to confusion about the transformations needed.
Lilian Sa
gravity and mertices
I posted a thread yesterday and I think that I did not formulated it properly.
So I have a metric ##{ds}^{2}=-{dt}^{2}+{dx}^{2}+2{a}^2(t)dxdy+{dz}^{2}##
I was asked to find the the coordinate transformation so that I can get a diagonalized metric.
so what I've done is I assumed a coordinate transformation ## x=\tilde{x}+F(t,y) ## replaced it in the metric and equated to zero for the proper elements.
but what does that says that F have to be dependent on the other coordinates?
I've got complicated with it.
thanks for any help :)
If you make the substitution ##x = \tilde{x} + F(t,y)##, then ##dx = d \tilde{x} + (\partial_t F) dt + (\partial_y F) dy##. So in your original expression for ##ds^2##, try replacing ##dx## by the more complicated expression and see if you can find a choice of ##F(x,y)## that will make the cross-terms such as ##dx dy## vanish.
This is what I got at the end:
## ds^2=-dt^2(1-\partial_tF)+d\tilde{x}^2+(\partial_yF+2a^2\partial_yF)dy^2+dz^2+d\tilde{x}dy(sa^2+2\partial_yF)+dtdy(2a^2\partial_tF+2\partial_tF\partial_yF)+d\tilde{x}dt(2\partial_tF) ##
that means that I got ##F ## does not depend on any coordinate!
but this is not true, there's something wrong with the answer right?
You didn't necessarily make a mistake. It might be that you just made an incorrect guess about the form of the transformation.
In general, you would have ##t, x, y, z## as functions of ##\tilde{t}, \tilde{x}, \tilde{y}, \tilde{z}##, so there would be 4 different functions and 16 partial derivatives to worry about. Hopefully, you don't need that level of complication, but your first guess was too simple.
The next thing to try is to transform both ##x## and ##y## (and leave ##t## and ##z## alone).
Let ##x = \tilde{x} + F(\tilde{y}, \tilde{t})## and ##y = G(\tilde{y}, \tilde{t})##.
Then ##dx = d \tilde{x} + \dfrac{\partial F}{\partial \tilde{y}} d \tilde{y} + \dfrac{\partial F}{\partial t} dt##.
##dy = \dfrac{\partial G}{\partial \tilde{y}} d \tilde{y} + \dfrac{\partial G}{\partial t} dt##.
I spent more time than I should have trying to solve this problem, and I don't actually know how to do it. If ##a^2## were constant, then you could let ##x = \tilde{x} - a^2 y##, and that would diagonalize it. However, if ##a^2## is a function of ##t##, then ##dx = d \tilde{x} - \dfrac{d(a^2)}{dt} y dt - a^2 dy##. Then when you square it, you get additional cross-terms ##-2 \dfrac{d(a^2)}{dt} y dt d \tilde{x}##.
but this additional cross term we have to equate it to zero and then we get the expression equal to zero, but that doesn't help :(
or I am wrong?
I'll try rhis today, hope it will work.
thanks very much!
thanks very much!
I'm not convinced that there is any simple solution. The most general transformation involves three functions
##t = T(\tilde{t}, \tilde{x}, \tilde{y})##
##x = X(\tilde{t}, \tilde{x}, \tilde{y})##
##y = Y(\tilde{t}, \tilde{x}, \tilde{y})##
Then there are 9 partial derivatives:
##\partial_{\tilde t} T, \partial_{\tilde x} T, \partial_{\tilde y} T##
##\partial_{\tilde t} X, \partial_{\tilde x} X, \partial_{\tilde y} X##
##\partial_{\tilde t} Y, \partial_{\tilde x} Y, \partial_{\tilde y} T##
The constraint that ##ds^2## is diagonal in the ##\tilde{t}, \tilde{x}, \tilde{y}## coordinate system gives 3 equations. So we have more unknowns than equations, so we should have the flexibility to choose simplifying assumptions. For example, assume that ##T## does not depend on ##\tilde{y}## or that ##Y## does not depend on ##\tilde{t}##. But every such choice that I have thought of has led to an inconsistent set of equations.
An approach that might give you an answer "in the limit" is this:
As I mentioned earlier, the case where ##a^2## is constant is diagonalizable. So my idea is to assume that
##a^2 = q(\lambda t)##
and expand ##a^2## in a power series in ##\lambda##:
##a^2 = q(0) + \lambda q'(0) + \lambda^2/2 q''(0) + ...##
Now, you perform a sequence of transformations.
The first transformation attempts to make the non-diagonal terms of order ##\lambda##.
The second transformation attempts to make the non-diagonal terms of order ##\lambda^2##.
Etc.
Can you verify that there's no ##dy^2## term in the original metric? In your other thread, the matrix you started with included one.
I don't think so, because we have to get a diagonalized metric with the four coordinates, which include Y or the transformed Y.
Wow! I found a mind-blowing solution to a related problem. Suppose instead of ##a^2## being a function of ##t##, it was a function of ##\tilde{t}##?
So we make the following simplifying assumptions for this case:
##t = T(\tilde{x}, \tilde{y})## (note: ##t## does NOT depend on ##\tilde{t}##)
##y = Y(\tilde{x}, \tilde{y})## (note: ##y## also does not depend on ##\tilde{t}##)
##x = X(\tilde{x}, \tilde{t})## (note: ##x## does not depend on ##\tilde{y}##
Then it is possible to choose a transformation that makes ##ds^2## diagonal, as long as ##a^2## is a function of only ##\tilde{t}## (rather than ##t##).
But it was given in the question that ##a## depends on ## t ## , I don't know if its legal to suppose that it does not depend on ## t ##. :(
No, it's not. I don't think the original problem has any good solutions, though.
  • · Replies 40 ·
  • · Replies 22 ·
