How Can Engineering-Based Blood Filtering Help Treat COVID?
  • Thread starter Thread starter cmb
    Covid
The discussion centers on the potential for engineering-based blood filtering to treat COVID-19 by addressing microclotting, which is identified as a cause of hypoxia. Participants suggest that while traditional dialysis machines may not be suitable, a specialized machine could be developed to filter blood and remove microclots. Current treatments include ECMO (extracorporeal membrane oxygenation) and low molecular weight heparin, which prevent clotting before it becomes problematic. The complexity of COVID-19 pathology, including the immune response and microclot formation, necessitates further research into effective treatment modalities.
  • Understanding of microclotting and its implications in COVID-19 pathology.
  • Familiarity with ECMO (extracorporeal membrane oxygenation) and its clinical applications.
  • Knowledge of low molecular weight heparin and its role in antithrombotic therapy.
  • Awareness of cytokine storms and their impact on lung tissue in COVID-19 patients.
  • Research the design and functionality of specialized blood filtering machines for microclot removal.
  • Investigate the latest studies on ECMO usage in COVID-19 treatment and its limitations.
  • Explore the mechanisms and monitoring protocols for low molecular weight heparin in preventing clotting.
  • Examine the relationship between cytokine storms and microclot formation in COVID-19 patients.
Medical researchers, healthcare professionals, engineers in medical device development, and anyone involved in COVID-19 treatment strategies will benefit from this discussion.
cmb
TL;DR
Can an improved form of dialysis treat COVID?
I am watching the video in this post;-
https://www.physicsforums.com/threa...es-over-time-a-big-issue.1008171/post-6554749
(yes, I do fully read and try to understand people's posts, not sure it is reciprocated)
and I was unaware of the content of the video, where he says the reason for hypoxia is due to micro clotting (see at 10'22'' specifically) got me thinking;-
If that is the case, then can't we do something 'engineering based' about that, by taking the blood out and filtering out these microclots?
I imagine a regular dialysis machine would clot up, but I am sure a machine designed to flow and filter blood that is in the process of forming microclots can be devised to do that job with?
Just a thought. Could this work and if so has this approach been considered/tried already?
Reason no such machine already exists is, as this guy says, there has never been a disease like this before. So maybe time to make such a machine?
Biology news on Phys.org
cmb said:
Summary:: Can an improved form of dialysis treat COVID?
Ok intuitively that made sense but can you post some of the published papers time lining the points?
I know all the guys have posted papers on some of the pathologies already.
Be good to timeline this though, if all those points are supported.
ECMO (major dialysis with oxygen exchanger) is currently used for some patients with extremely serious symptoms. Usually after patients start to fail on ventilators. It involves oxygenating blood that is rerouted out the thigh, into the ECMO, back into the blood stream.
So you have a good idea in that what you suggest could be done. No major problem conceptually.
ECMO is a high volume dialysis system. In use as we speak.
Except a coicnern may be perhaps how to remove clotting and keep patients healthy. And get access ECMO-like machines. Or maybe dialysis machines could perform the task. I do not know any research on this topic.
Note: ECMO is a big deal clinically. It is also limited in availability because it mostly is used in for newborns, with heart/lung problems. Patients are often airlifted to fairly distant sites that have the staff and available ECMO devices. This is in New Mexico.
However. ECMO is considered an extremely last resort, because of increased risk problems.
The clot issue has a much less intrusive answer:
Low molecular weight heparin (an antithrombotic - prevents clotting) is one of the major treatment modalities for patients considered at risk for severe clotting. Usually administered before micro-clots become a problem. Otherwise it has no benefit. It has to be monitored so that patients do not develop internal bleeding. It is not a trivial drug, people can die from poorly monitored use.
ECMO guidance from the CDC:
https://www.covid19treatmentguidelines.nih.gov/management/critical-care/extracorporeal-membrane-oxygenation/
Heparin guidance from the CDC:
https://www.covid19treatmentguidelines.nih.gov/therapies/antithrombotic-therapy/
Consider this:
The point is to prevent clotting in the first place. Why? Ex post facto remediation may run into the problem that the microclots form on/around the alveoli and do not necessarily float around loose. I do not know how valuable removing clots after formation would be for patient survival.
And once the clots form, then the pathology really "hits the fan", i.e., escalates rapidly.
This is about microclots:
https://pubmed.ncbi.nlm.nih.gov/32972126/
Explains what I am talking about. The microclot damaged area looks like ground glass in thoracic X-rays.
Clots do get around and cause problems, as you would expect, but the primary damage zone is the alveoli in the lungs. They stay there in droves. Plus it is not just the clots. The immune system overreacts and trashes alveolar tissues as well. Cytokine storm.
The pathology of Covid is truly complex. This is one big reason it took the medical community extensive effort to work out the guidelines above.
Likes pinball1970, cmb and Astronuc
As child, before I got my first X-ray, I used to fantasize that I might have a mirror image anatomy - my heart on the right, my appendix on the right. Why not? (Caveat: I'm not talking about sci-fi molecular-level mirroring. We're not talking starvation because I couldn't process certain proteins, etc.) I'm simpy tlakng about, when a normal zygote divides, it technically has two options which way to form. Oen would expcet a 50:50 split. But we all have our heart on the left and our...
  • · Replies 65 ·
11K
