Calc Min Steel Wire Diameter for 323kg Load
  • Thread starter Thread starter iamtrojan3
    Diameter Wire
The minimum diameter of a steel wire required to support a 323 kg load without exceeding a stretch of 7.38 mm is calculated using Young's modulus, which is 200.0 GPa. The formula applied is Young's modulus = (Force / Area) / (change in length / original length). After calculations, the correct radius is approximately 0.0069 m, leading to a diameter of about 0.0138 m. The discrepancy in results may arise from rounding errors or significant figures.
  • Understanding of Young's modulus and its application in material science.
  • Basic knowledge of physics, specifically force and tension calculations.
  • Familiarity with unit conversions, particularly between millimeters and meters.
  • Proficiency in algebraic manipulation and solving equations.
  • Study the principles of Young's modulus in detail.
  • Learn about tensile strength and its implications in engineering materials.
  • Explore significant figures and their importance in scientific calculations.
  • Investigate the effects of different gravitational constants on material stress calculations.
Students in engineering or physics, material scientists, and anyone involved in structural design or analysis of materials under load.
iamtrojan3
Find the minimum diameter of an l = 17.2 m long steel wire that will stretch no more than 7.38 mm when a mass of 323 kg is hung on the lower end. (Hint: The Young's modulus of steel is 200.0 GPa.)
Youngs = (Force / Area) / (change L / L)
= (mg / pi*r^2) / (change L / L)
Simple enough... just plug and chug right?
just to clarify, 200.0GPa = 2x10^11 N/m^2 correct?
and 7.38mm = 0.00738m
If so,
Then after solving for r... i got .006853m, which is wrong. And i did multiply by 2 for the diameter. 0.0685 is also wrong, so is .685m
What am i doing wrong?? or am i just way off??
Thanks
What value of g did you use?
I used the same formula as you did and I get 0.0069 m. Do you know the correct answer?
Sorry for not replying earlier... fell asleep.
I used 9.81 as g, and idk what the right answer is... =(
You have the right answer. Maybe you have the wrong number of significant figures, or are rounding incorrectly.
g=9.81 gives 6.86 mm, and g=9.80 gives 6.85 mm for the diameter.
  • · Replies 18 ·
  • · Replies 19 ·
