Diatomic molecule at a constant temperature
LCSphysicist
All below...
A diatomic molecule ##D_{2}## in ##30K##, in ##t=0##, is in the state ##| \psi (0) \rangle = \frac{1}{\sqrt{26}}(3 | 1,1 \rangle + 4| 7,3 \rangle + | 7,1 \rangle )##, where the kets denote states ##| l,m \rangle##. Use ##\frac{\hbar}{Ic4\pi}=30.4cm^{-1}##.
Obtain ##| \psi (t) \rangle ##
I think the main point here is to deduce what is the Hamiltonian of the system. But i don't know what could i use!
First i thought it could be a rotator, so ##H = \frac{L^2}{2I}##. But doing so, i am not sure how the temperatura enters in the problem!
It seems that the probability should follows the canonical formalism, so ##P \propto e^{-\beta E}##, where ##P## is the probability of the state with energy ##E##. But how to connect it to a rotator?
(If the rotator idea is correct)
Without an explicit coupling to the environment, there is no way to solve this for the case of constant temperature.
As the molecule is in a pure state at ##t=0##, I would continue treating it as an isolated system and disregard the mention of temperature.
