- 9,864
- 4,896
and Peter Watkins' 1965 "The War Game" ..Bandersnatch said:You should watch Threads sometime.
Reactivity transients (and explosions) take place over millisecond time frames. In PWRs, some tests have pulse widths of 10 to 30 ms, so the megatons would be greatly reduced to tons. During a pulse, the power can be many times the steady state level, usually less than a factor of 10. However, I have not seen numbers for the pulse height (peak power level) or pulse width for Chernobyl 4.jim hardy said:Can we just call it 2 megatons per month? 24 megatons per year?
How long had Chernobyl run in that fuel cycle prior to the explosion ?
Anyhow -
That'd be my guess
as to why a pyhysicist told them to expect consequences similar to a few megatons ,
Astronuc said:However, I have not seen numbers for the pulse height (peak power level) or pulse width for Chernobyl 4.
I'm more familiar with the CANDU system, but I understand in both cases, the refueling machine locks onto the cooling channel, then the cap is removed, the spent fuel is retrieved and fresh fuel inserted, then the cap is returned and locked. I don't know if there are valves to block/stop the coolant flow into the channel, but perhaps there is.artis said:PS. @Astronuc , even though a bit off topic, I wonder when they changed a fuel assembly while reactor is online, as the fuel assembly comes out, did they close the water flow of that specific channel beforehand? Otherwise I fail to see how this would not result in hot water/steam spewing everywhere.
What still intrigues me is how each assembly rod had a seal that could be tightened or loosened by the remote machine in order for the channel to be sealed before being put back into operation. I assume CANDU'S have similar things since their also channel type.
Agreed . The energy released in the explosion is orders of magnitude less than a weapon generates.Astronuc said:...so the megatons would be greatly reduced to tons.
Ref:https://www.pbs.org/wgbh/pages/frontline/shows/reaction/readings/chernobyl.htmlThe resulting radioactive release, Medvedev estimates, was equivalent to ten Hiroshimas. In fact, since the Hiroshima bomb was an airburst--no part of the fireball touching the ground--the Chernobyl release polluted the countryside much more than ten Hiroshimas would have done.
I believe it is quite natural to compare fallout from nuclear weapons tests, since there was substantial fallout and contamination from atmospheric tests.artis said:Isn't it a bit misleading in general to compare fallouts from exploded very specific design nuclear reactors (specific design in a way that only worsens the damage, aka burning graphite etc) and nuclear bombs?
Every bomb ever has had the chance to fission for a very brief amount of time versus a reactor that has piled up large amounts of fission products , especially the RBMK given it had the largest sized core of all known commercial reactors and I guess also the most fuel in tons compared to other smaller cores.
Just asking.
I believe the areas of the Marshall Islands, e.g., Bikini and Eniwetok atolls are off-limits due to contamination, and I believe other areas where weapons were tested are exclusion zones, e.g., Maralinga in South Australia.As far as I am aware of all the countless nuclear bomb detonation places none is so heavily polluted that it requires a sealed off exclusion zone.
The problem is that [my understanding is] the movie is presented as a historical documentary, not a dramamentary* or even historical fiction, and it is being discussed in a technical section of PF, not the sci-fi section.Rive said:I have a feeling that what @russ_watters is annoyed about is the hysteria around the movie, and not about the hysteria in the movie... What is indeed getting really annoying. It is getting really hard to do any search for facts, and it is just started to spin... I've already started using time-limited search: any hit from the past half year excluded.
The movie is a psychological/societal drama based on really well gathered background, but adapted to TV/movie. I see less and less reason to discuss the content of the movie (!) in science topics.
FYI, Philly is 25 miles from the Limerick nuclear plant and I live 6 miles from the plant. She's panicking over the plant while I'm happy it isn't a coal plant.This is a point that the creator of “Chernobyl,” Craig Mazin, has stressed. “The lesson of Chernobyl isn’t that modern nuclear power is dangerous,” he tweeted. “The lesson is that lying, arrogance, and suppression of criticism are dangerous.”...
Personally, I’m not so sure. Having now watched all five episodes of “Chernobyl,” and seen the public’s reaction to it, I think it’s obvious that the mini-series terrified millions of people about the technology...
“I watched the first episode of Chernobyl,” tweeted Sarah Todd, a sports writer at the Philadelphia Inquirer. “Then I spent a couple of hours reading about nuclear power. Now I’m in a full blown panic and I need someone to explain to me how it is at all okay to live on the east coast when this is the situation.”
The title topic of this thread is of course another example of an event that didn't happen (discussed in the article).In interviews around the release of HBO’s “Chernobyl,” screenwriter and show creator Mazin insisted that his mini-series would stick to the facts. "I defer to the less dramatic version of things,” Mazin said, adding, “you don’t want to cross a line into the sensational."
In truth, “Chernobyl” runs across the line into sensational in the first episode and never looks back...
“Chernobyl” ominously depicts people gathered on a bridge watching the Chernobyl fire. At the end of the series, HBO claims, “it has been reported that none survived. It is now known as the "Bridge of Death.”
But the “Bridge of Death” is a sensational urban legend and there is no good evidence to support it...
The New Yorker repeated the claim that a woman’s baby “absorbed radiation” and died. The New Republic described radiation as “supernaturally persistent” and contagious (a “zombie logic, by which anyone who is poisoned becomes poisonous themselves”). The Economist, People, and others repeated the “bridge of death” urban legend.
| Primary use | Generation of electricity and production of weapon grade plutonium |
russ_watters said:FYI, Philly is 25 miles from the Limerick nuclear plant and I live 6 miles from the plant. She's panicking over the plant while I'm happy it isn't a coal plant.
Amen .. I worked in one for thirty years.artis said:PS. @russ_watters I totally agree I too would have nothing against living next to a reactor but a modern one operated by sane people like the one you are living next to, not an RBMK pre-upgrade version one operated by sociopaths and high school students (Toptunov was 25 and inexperienced)
Oh Pu-lease, don't restart that GW debate here.dangderang2000 said:That's a current topic where the scientists, much like the Soviet ones, are fighting for the truth while the powers at be try to silence them.
dangderang2000 said:Towards the end, there's also a not so subtle reference to the fight about the truth around climate change. That's a current topic where the scientists, much like the Soviet ones, are fighting for the truth while the powers at be try to silence them.
artis said:I would assume that bringing the fuel together in a molten ball like shape would increase its reactivity when a moderator is introduced?
In general, this kind of recriticality events are expected to be a kind of slow/pulsing reactions like in Tokaimura: as the water boils, the reactions subsides, then with the water cooling down it starts again.jim hardy said:so a return to criticality just long enough to make another big steam explosion is i believe not implausible.
Not necessarily, and more unlikely, to the first question. No to the second question.artis said:I would assume that bringing the fuel together in a molten ball like shape would increase its reactivity when a moderator is introduced? This IIRC is also the reason why molten salt reactors needed less fuel mass for criticality right?
