Did I Calculate the Correct Angle for TIR in a Glass Prism?
  • Thread starter Thread starter Alain12345
The discussion revolves around the calculation of angles for total internal reflection (TIR) in a glass prism with a refractive index of 1.44. The user initially calculated angles using Snell's Law, determining that the angle for the ray exiting the prism is 30 degrees. They acknowledged a mistake in their diagram regarding the placement of the 62-degree angle, clarifying that it should be measured from the normal to the ray. The confirmation of the calculations indicates that TIR occurs when the angle exceeds the critical angle of 44 degrees. The final consensus is that the exit angle of 30 degrees is correct.
Alain12345
I completed a question about TIR in a glass prism, and I was wondering if someone can tell me if I got it right. Thanks
"Less" and "more" refer to the less dense medium and more dense medium, and the red line is the normal.
http://img145.imageshack.us/img145/7061/tirquestion0mi.png
Question: Determine all the necessary angles and then calculate at which angle the ray exits the prism. n= 1.44
Calculations:
n= sin less/sin more
1.44= sin 62/sin more
sin 62/1.44= sin more
angle more= 38
_________________
1.44= sin less/ sin 60
angle less= N/A
therefore, sin C= 1/n
sin C= 1/1.44
= 0.6944
Critical angle= 44
angle more is greater than critical angle, therefore TIR occurs
__________________
1.44= sin less/ sin 20
angle less= 30
The ray exits the prism at 30 degrees.
EDIT: I put the 62 in the wrong place, I meant it to be in between the normal and ray
The angle that is used in Snell's Law : sin(theta)
is the angle measured from the NORMAL line to the RAY.
The 62 degree angle, according to your diagram,
is measured from the SURFACE to the ray.
I'm sorry, I put the 62 in the wrong place when I was makign the diagram. It should be between the normal and the ray
Then your work is Okay.
You don't really need to compute the critical angle (paragraph 3)
... if the sin(less) is supposed to be greater than 1,
then that "less" angle does not exist, and Tot.Internal Reflection occurs.
So 30 degrees is okay for my final answer? Thanks a lot! :smile:
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
