Did rotating polarizer show violations of Bell's Inequality?
The discussion revolves around the implications of Bell's inequality in the context of a rotating polarizer experiment. Participants explore the conditions under which the inequality is tested, the role of reference frames, and the nature of entangled photons. The conversation includes theoretical considerations, experimental setups, and interpretations of results.
  • One participant outlines the conditions of Bell's inequality and questions the validity of certain terms based on reference frames and Noether's theorem.
  • Another participant asserts that measurements are conducted in a well-defined lab frame, suggesting that reference frames do not impact the Bell test.
  • Concerns are raised about the interpretation of entangled photons, with some arguing they are in a superposition of polarizations rather than having common polarization.
  • A participant discusses the implications of predetermined measurement results and how they relate to the agreement or disagreement of measurements in Bell tests.
  • There is a mention of the statistical nature of entangled photon states and how they differ from mixed light sources.
Participants express differing views on the relevance of reference frames, the nature of entangled photons, and the interpretation of measurement results in relation to Bell's inequality. No consensus is reached on these points.
Participants highlight the complexity of the Bell test and the assumptions involved, including the hidden variable hypothesis and the implications of measurement settings. The discussion reflects ongoing uncertainties and challenges in interpreting experimental results.
  • #31
Ian J Miller said:
The joint probability is given sin squared
As I have already asked once: what do you think the sin squared function represents? It's a simple question and you should be able to give a simple answer without another wall of text.
  • #32
Ian J Miller said:
from Bell (pp 9 - 10 of the reference above) the initial position is the plus and minus detectors at right angles to each other.
I am unable to recognize this as a reference to anything in Bell's "Bertlmann's socks" paper.
  • #33
For an entangled pair, where one photon gives a click on the first detector, the sin squared function surely represents the probability that the partner photon will give a click on its detector, the term θ being the difference between rotations of the two detectors from the initial position.
The reason for "the walls of text" is that when I initially asked the question, none of the responses addressed what I was asking so I felt I had to elaborate.
This is NOT a personal theory. It is questioning how a term that should have a single value in the derivation of a relationship appears to have multiple values when these are used to argue that said mathematical relationship is violated. It is a simple question. Either a term such as B- should be required to have one value or it should not, and if not there should be some sort of derivation that shows what its limits are.
I am sorry you do not get what I see as a problem, but I have done all I can to explain it. There is probably no point in continuing this because it appears I cannot seem to make any progress.
  • Sad
  • #34
Probability according to which theoretical model?
The reason you are having difficulty getting helpful responses is that nobody but you can understand how you are even getting to this belief in the first place. That's why I think it would be much better if, instead of trying to inundate us with your personal derivations, you would point us to explicit quotations and equations from whatever reference you are using that you think justify this belief of yours.
  • #35
In the spirit of taking my own advice, I am going to give the answer to this question by quoting from Bell's Bertlmann's socks paper. I am using the PDF version that can be found on CERN's website [1].
Equation (4) in that paper gives probabilities in terms of the sin squared function. As the paper says, these are probabilities according to quantum mechanics, i.e., that is the theoretical model used to derive them. For simplicity I'll just give the probability of a match (up/up or down/down):
P_\text{QM} = \frac{1}{2} \sin^2 \frac{\theta}{2}
where ##\theta## is the difference in angles, called ##a - b## in the paper.
Equation (3) in that paper gives probabilities as they are derived from a different theoretical model, a "Bertlmann's socks" type of model:
P_\text{socks} = \frac{| \theta |}{\pi}
Bell's argument is then a simple one: ##P_\text{socks}## does not match ##P_\text{QM}## except at an isolated set of values of ##\theta##, namely, ##0##, ##\pi / 2##, and ##\pi##. So no "Bertlmann's socks" type of model can match the predictions of QM over the entire range of possible angles.
@Ian J Miller you talk of "multiple values". Where are the multiple values here? For any given actual run of an actual experiment, ##\theta## will have one value. And we can compare the two probabilities, using the above formulas, at whatever that value is, and see that they don't match unless that value is one of the three isolated ones I gave above. That is what all of the experimental tests end up boiling down to.
[1] https://cds.cern.ch/record/142461/files/198009299.pdf
  • #36
The model involves the sin squared relationship. It is equivalent in this circumstance to the Malus law, which applies to a polarized wave.
The sin squared 22.5 and 45 degrees was used by Bell in the second equation of p 10.
I explained my reason for multiple values. Take C-. If you ran C+ and C-. then C- = 0. If you run B+ and C-, C- takes the value 0.146. If you run A+ and C- then C- takes the value 0.5. That means that C- is a function, b ut in the derivation it occurs several times as a single term.
My problem was most simply seen by looking at A+.B- and B+.C- . These are the same results, and all that has happened is we have rotated both detectors by 22.5 degrees, so the angle between them is constant (leaving aside the question of exactitude). Now, according to Noether's theorem, that is merely one result repeated. The answers here say Noether's theorem does not apply, without saying why it doesn't.
I am sorry I asked this question. It relates to what the terms actually mean. Experimental tests are not relevant if the terms used are not clearly defined. The derivation of the inequality I gave requires the terms to take one value under one set of circumstances. Yes, the difference between socks and photons occurs because you add up socks to get probabilities. For photons, there is the wave aspect, wherein conservation of energy arises because cos squared plus sin squared equals 1 so the difference between orientation of polarised wave detectors is one of the two trig functions, depending on what you are projecting onto.
I think it might be better if we terminate this discussion now because we are not discussing the same thing. Thank you for your time.
  • #37
The quantum mechanical model does, yes.
But the "Bertlmann's socks" model that is used to calculate the Bell and CHSH inequalities does not.
If you have not grasped this simple fact, you have not read the paper you referenced very carefully.
No, as has already been pointed out, the QM model is not equivalent to Malus' law. That law is a classical approximation. You should not expect classical approximations to work for these experiments.
Yes, because there he is calculating the quantum mechanical predictions for the correlations. Nothing he says that involves the sin squared function has anything whatever to do with deriving any inequalities. He is just showing that the QM prediction violates them.
Again, if you have not grasped this simple fact, you have not read the paper very carefully.
What derivation? Where is this in the paper you referenced?
Whether you want to post any further is of course up to you. But it seems to me that the reason for the difficulties in this thread is that you have insisted on using your own idiosyncratic derivation and notation that nobody else can understand, despite the fact that you referenced an actual paper. You could have given explicit equation numbers and quotations from text in that paper. But you didn't. The only time you have even talked about such things is when I forced you to by referencing them myself. And even then you only did it for a little bit, and then reverted to your former failed strategy, so that I have had to pose a follow-up question to you above that I shouldn't have had to pose at all.
  • #38
No, that's not Noether's theorem, that's just rotational invariance. Noether's theorem says that, because the laws of physics are rotationally invariant, angular momentum is conserved.
Even with this correction, however, your claim here is wrong. Rotational invariance does not say that if run 2 of some experiment looks just like run 1 rotated by some angle, then they are really the same run. But that is what you are arguing here.
  • #39
The terms used in the inequalities are perfectly well defined: they are the actual observed correlations between the two measurements, for different settings of the measurement angles. If this wasn't well defined, how could the experimenters even collect and analyze the data?
  • #40
Why should I, or anyone actually doing these experiments, care about your derivation?
The people who actually do these experiments don't have any trouble understanding what the terms in the inequalities mean, or how the inequalities were derived, or how to calculate the numerical values from their data. If you are correct, they must all be doing something obviously wrong. What is that thing?
  • #41
If you have not grasped this simple fact, you have not read the paper you referenced very carefully.No, as has already been pointed out, the QM model is not equivalent to Malus' law. That law is a classical approximation. You should not expect classical approximations to work for these experiments.Yes, because there he is calculating the quantum mechanical predictions for the correlations. Nothing he says that involves the sin squared function has anything whatever to do with deriving any inequalities. He is just showing that the QM prediction violates them.
Again, if you have not grasped this simple fact, you have not read the paper very carefully.What derivation? Where is this in the paper you referenced?Whether you want to post any further is of course up to you. But it seems to me that the reason for the difficulties in this thread is that you have insisted on using your own idiosyncratic derivation and notation that nobody else can understand, despite the fact that you referenced an actual paper. You could have given explicit equation numbers and quotations from text in that paper. But you didn't. The only time you have even talked about such things is when I forced you to by referencing them myself. And even then you only did it for a little bit, and then reverted to your former failed strategy, so that I have had to pose a follow-up question to you above that I shouldn't have had to pose at all.
The Bertlmann socks does not use the sin squared because there are no waves involved.
You say the QM model is not equivalent to the Malus law, but it counts joint probabilities with the same function.
I never said the sin squared was involved in deriving the inequality; I said that it was not. This is further evidence that you are not understanding what i wrote. That is your right.
  • #42
Let me ask you this, then. If you did an experiment on one end of the bench and translated it to the other end, can you call that a new set of results, or are you reproducing the first result?
  • #43
When you say, what is that thing? what do you think the above discussion is about? As an aside, I am not saying they are wrong; I am asking you why you and others think they are right.
I have explained my problem to the best of my ability. So far, nobody seems to understand the question I am putting, so i think this is no longer useful to me or anyone else.
  • Skeptical
  • #44
Wrong. It doesn't use the sin squared because it is not a quantum model, it is a local hidden variable model.
For this particular case, perhaps. That still doesn't mean you can expect to apply classical reasoning to a quantum model.
Then I fail to see why you keep talking about it, since your point, to the extent you have a coherent point, appears to be that there is something about the way the inequalities are derived that makes them somehow not apply the way they are claimed to apply to the experiments that are supposed to test them.
Do you mean, move to the other end of the bench and then do another experiment that has (to within experimental error) the same initial conditions and measurements?
In what follows, I'll assume that the answer is yes.
Both. I am generating a second set of results, which, given the identical initial conditions and measurements and the fact that the laws of physics are translation invariant, I expect to be identical, to within experimental error, with the first set of results.
What is your point with all this?
I have no idea. That's why I keep asking you to actually quote equations and text from the paper you referenced in order to make whatever point you are trying to make. I understand the paper you referenced, so if you are quoting equations and text from that, I will at least be able to start from a point that I understand, in order to try to grasp whatever point you are trying to make. When you insist on trying to make your point using your own idiosyncratic notation and your own made up derivations, on the other hand, I have no point to start from at all, since I can't make sense of either your notation or your derivations.
Um, because I and others (including the theorists and experimenters themselves) understand the derivations and equations and arguments they are using and agree that they are correct?
Everything is laid out right there in Bell's papers. What's wrong with his arguments? In my opinion, and apparently in the opinion of the theorists and experimenters in this field who have spent several decades now doing more and more accurate experiments and confirming everything Bell said, nothing. Isn't that a good enough reason to think they are right?
I strongly doubt that. I strongly doubt that it is beyond your ability to quote some actual equations and text from the paper you reference that will illustrate whatever point you think you are trying to make.
More precisely, I strongly doubt that would be beyond your ability, if you had an actual coherent point to make. So the fact that you have not done this obvious thing just indicates to me that you do not.
I have already explained why that is, multiple times now. See above.
  • #45
To sharpen the question I ask at the end of this quote, let me run with the implied analogy you made here. In the case of the experiments described in Bell's Bertlmann's socks paper, we have two sets of runs where the difference in angles is the same, 45 degrees: we have runs where one measurement is done at 0 degrees and one is done at 45 degrees, and we have runs where one measurement is done at 45 degrees and one is done at 90 degrees. Rotational invariance says that, to within experimental error, the correlations observed in both sets of runs should be the same.
But rotational invariance does not tell us what those correlations should be, numerically. For that, we need a theoretical model. And both theoretical models that Bell uses in his paper, the QM one and the Bertlmann's socks one, satisfy rotational invariance: both of them predict that the correlations in both sets of runs described above should be the same. But they predict different numerical values for those correlations: the QM model predicts a correlation of ##\sin^2 22.5 / 2##, or ##.0732##, for both sets of runs, while the Bertlmann's socks model predicts a correlation of ##22.5 / 180## (since we're using degrees, the denominator is ##180## instead of ##\pi##), or ##.125##, for both sets of runs. Rotational invariance gives us no help at all in deciding between these theoretical models. So what's the point of bringing it up?
  • #46
Maybe it would tremendously help, if the OP would read a good textbook's treatment of the Bell inequalities. Bell's papers are sometimes not so easy to understand, because he has a quite special language of his own and is a bit too much inclined towards philosophy rather than pure physics.
A very clear philosophy-free treatment of Bell's inequalities and their violation according to QT can be found in
S. Weinberg, Lectures on Quantum Mechanics, Cambridge
University Press, Cambridge, 2 edn. (2015),
https://www.cambridge.org/9781107111660
  • #47
For this particular case, perhaps. That still doesn't mean you can expect to apply classical reasoning to a quantum model.Then I fail to see why you keep talking about it, since your point, to the extent you have a coherent point, appears to be that there is something about the way the inequalities are derived that makes them somehow not apply the way they are claimed to apply to the experiments that are supposed to test them.Do you mean, move to the other end of the bench and then do another experiment that has (to within experimental error) the same initial conditions and measurements?
In what follows, I'll assume that the answer is yes.Both. I am generating a second set of results, which, given the identical initial conditions and measurements and the fact that the laws of physics are translation invariant, I expect to be identical, to within experimental error, with the first set of results.
What is your point with all this?I have no idea. That's why I keep asking you to actually quote equations and text from the paper you referenced in order to make whatever point you are trying to make. I understand the paper you referenced, so if you are quoting equations and text from that, I will at least be able to start from a point that I understand, in order to try to grasp whatever point you are trying to make. When you insist on trying to make your point using your own idiosyncratic notation and your own made up derivations, on the other hand, I have no point to start from at all, since I can't make sense of either your notation or your derivations.Um, because I and others (including the theorists and experimenters themselves) understand the derivations and equations and arguments they are using and agree that they are correct?
Everything is laid out right there in Bell's papers. What's wrong with his arguments? In my opinion, and apparently in the opinion of the theorists and experimenters in this field who have spent several decades now doing more and more accurate experiments and confirming everything Bell said, nothing. Isn't that a good enough reason to think they are right?I strongly doubt that. I strongly doubt that it is beyond your ability to quote some actual equations and text from the paper you reference that will illustrate whatever point you think you are trying to make.
More precisely, I strongly doubt that would be beyond your ability, if you had an actual coherent point to make. So the fact that you have not done this obvious thing just indicates to me that you do not.I have already explained why that is, multiple times now. See above.
The socks is a hidden variable model? What is the hidden variable? The number of socks is clearly defined, the temperatures are measured, the length of the socks, say is measured. All is explicit. You may not know why the socks shrink, but that is not a hidden variable - it is an unexplored reason, probably due to protein folding and reorganization, which we expect to unravel with techniques like an electron microscope. As I understand it, a hidden variable is something you cannot measure. For example, in Bohm's pilot wave, the position of the particle is a hidden variable (as is presumably his quantum potential).
The connection between classical and quantum physics is that if sufficient data are obtained that you can get expectation or average values, then these expectation values follow the relationships of classical physics. (Ehrenfest, P. 1927. Bemerkung über die angenäherte Gültigkeit der klassichen Machanik innerhalb der Quantenmechanik Z. Physik. 45: 455 – 457.) I have assumed we have collected sufficient photons to get the expectation values in their relationships, in which case the Malus Law should apply.
The sin squared relationship is the expectation relation for the probability that the second detector will count the entangled partner counted at the first detector and is hence a theoretical prediction. Providing you keep count properly, this is also measured.
My point with the translational experiment is suppose you measured something you label as A+B- at one end of the bench, and moved it to the other end, you are simply repeating the experiment and you are still measuring what you call A+B-. By the same reasoning, if you rotate both detectors in what you assign as the A+B- experiment, you are repeating the A+B- experiment, and indeed you get the same answer. To call it B+C- is simply an assertion. For the A+B- test, because you are only counting the second particle of an entangled pair, it is not a B at all, but a subset of A.
You wrote: "In my opinion, and apparently in the opinion of the theorists and experimenters in this field who have spent several decades now doing more and more accurate experiments and confirming everything Bell said, nothing. Isn't that a good enough reason to think they are right?" It is most certainly good enough to say the experiments gave the recorded results. That is without doubt. But if it is that right, why am I having so much trouble getting an explanation as to why simply rotating the detectors generates the third variable? Especially since moving the experiment within a symmetric environment has never done that elsewhere.
You wrote: "I can't make sense of either your notation or your derivations". The reason for using the inequality I did is that the question I am asking relates to the nature of the actual terms arising from the individual detectors. Most papers of which I am aware start with something like the CHSH inequality, that starts by assuming joint probabilities, in other words, the problem that is bothering me has already been assumed to be irrelevant. However, if you cannot follow the derivation I gave previously I can see why you are not understanding my question because it depends critically on what the terms actually mean.
  • #48
Now I am more confused. Bertlmann's socks were washed at three different temperatures. The degrees are degrees C, or K, not angles.
As far as theoretical models go, I was under the impression that the observed counts at the detectors, i.e. the count at detector 1, and the count at detector 2 arriving within x ns of a click at detector 1, were used to evaluate joint probabilities. These are simple measurements, with no theoretical model required. The sin squared relationship is from the theory, but is only used to see if the observed results follow expectation.
The point of bringing up the rotational invariance is how does rotating a fixed configuration generate two new variables when the symmetry of the source indicates it should be considered simply the same experiment.
I believe I showed above that if you use a polarized source, where all the pairs are polarized in one plane and there is no rotational symmetry, then the inequality is complied with, at least if the Malus Law applies. So if it is only when the source is rotationally invariant that we get the violations (of course the statement could be checked by experiment) why is everyone so sure that simply rotating both detectors by the same amount generates new variables?
  • #49
Bell starts out describing it that way, but he then points out that exactly the same logic that the socks model applies to socks, can be used to build a model of spin measurements at different angles, of the kind that are made in EPR experiments. So the properties of the socks model can also be used to derive predictions about correlations in such spin measurements. And, as he points out, those predictions are different from the QM predictions; the "socks model" predictions obey inequalities that the QM predictions violate.
That is literally the primary point of the paper you referenced. I am flabbergasted that you don't realize that since it is absolutely essential to understanding what Bell was talking about.
  • #50
No, that is not what Ehrenfest's theorem says. The equation he derived for expectation values only follows the same relationships as classical physics for certain expectation values under certain conditions. The claim you are making here is much stronger than that.
  • #51
No, your claim that it is "repeating the same experiment" is simply an assertion (and an unsupported and unfounded one). The experimental fact is that the detectors were rotated, and the experiment after the rotation was a separate experiment from the original one before the rotation. Recording the data from the two separate experiments as separate data is just being honest about what you actually did when the experiments were done.
Using rotational invariance to argue that the correlations from both experiments will be the same is a theoretical prediction, which then has to be compared with the actual experimental facts to see if it holds. You can't assert that they are "the same experiment", because that isn't what rotational invariance says anyway. Rotational invariance does not say that the two experiments, one before rotating the detectors and one after, are "the same experiment". It just says that those two separate experiments will give the same correlations.
  • #52
That is correct, yes; the observed correlations that are then compared with theoretical predictions are obtained this way (at least that's my understanding). And those observations are made (at least in experiments that are intended to test inequalities like CHSH) with 3 different pairs of angles, which Bell takes to be 0 and 45 degrees, 45 and 90 degrees, and 0 and 90 degrees. The fact that two of these three pairs are predicted (by both theoretical models in view) to give the same correlations (but with different numerical values for the correlations in the two different models), because of rotational invariance, does not change the fact that there are three distinct experimental runs, each of which gives its own measured correlation that then has to be compared with theoretical predictions. Rotational invariance, as I said in post #52 just now, is simply one of the theoretical predictions (and of course is found to hold).
  • #53
Of course I realize the sock model obeys the inequality, and the QM model does not, BUT the QM model only disobeys the inequality because the rotation of the polarizers in a set configuration when the source is rotationally invariant is allowed to introduce two new variables, when the only frame of reference, the angle between the two detectors, has also been rotated. My point is that if the source is polarized, i.e. it defines a fixed external frame of reference, the inequality is complied with. How can that happen, other than in one of the two cases something has gone wrong?
  • Skeptical
  • #54
If simply rotating the detectors against a rotationally invariant background generates the two new variables then you have provided your answer to the original question. Thank you.
  • #55
What is your basis for this claim?
  • #56
Um, what? Seriously? That was the issue? And now, from that one simple statement, you're convinced it's no longer an issue?
  • #57
I thought I put that up earlier, however, if this is a repeat, forgive me. There is no experiment as far as I know because nobody has tried it, but:
Assume a source that provides entangled photons, all of which are polarized in one plane. Align the A+ detector with this plane, and, as with Aspect, assign B as a rotation of 22.5 degrees and C as a rotation of 45 degrees. If so, A+ has a probability of 1 (assuming everything is perfect)- B- a probability of sin squared 22.5 and C- sin squared 45 degrees. In short, (A+)(B-) and (A+)(C-) are now the same as calculated for the Aspect experiment, however, (B+) now has a probability of cos squared 22.5 degrees, and C- is the same as above. Inserting these values into our derived inequality and we get
1 x 0.146 + 0.8536 x 0.5 should be ≥ 0.5.
which comes out to 0.573 ≥ 0.5,
  • #58
I was hoping to end the discussion.
  • #59
There is no such thing. If you restrict the polarization to one plane, there is no way to get an entangled state.
Of course if you ran this experiment, the correlations would not violate the Bell inequalities. But that is because of the lack of entanglement. You need quantum entanglement in order to obtain correlations that violate the Bell inequalities.
  • #60
Does that mean that the issue you were concerned about is no longer an issue?
  • · Replies 28 ·
16K
  • · Replies 80 ·
9K
  • · Replies 49 ·
  • · Replies 58 ·
