Dielectric Filled Parallel Plate Capacitor Question
4 replies · 4K views
SabreV45
A parallel plate capacitor has rectangular plates measuring 44.0 cm by 30.0 cm, and can be charged to 1600 V maximum ΔV without electrical breakdown. The gap between the plates is fulled with mylar dielectric (κ=3.2). Find the thickness of the dielectric.
C=κC0
C=Q/ΔV
C00(A/d)
I believe I am missing an equation needed to solve this question. The way I had this question set up, I wasn't able to solve without a value for Q.
C=κC0
C=Q/ΔV
C00(A/d)
The voltage across the dielectric + the voltage across the gap = your total voltage.
Remember in a constant field, voltage is just given as E*d.
And the equation you're missing is :
E(through dielectric) = E0/κ , with E0 the field between the plates without any dielectric.
Thanks for the info. I'm still not exactly sure how to solve for the thickness of the dielectric.
I'm mainly having problems setting up with question, once I get it set up I'll be able to solve everything myself. I'm just not able to think of a way to solve this question without having the value for Q.
Cheat. Look up the dielectric strength for mylar and determine the minimum thickness for 1600V breakdown. :smile:
I would prefer to be able to understand the calculations needed to determine the thickness of the dielectric. This was a question that I got wrong on a test and am trying to solve them correctly to keep in my records.
