Increasing Diesel Engine Efficiency with Retractable Plates
The discussion centers on the concept of increasing diesel engine efficiency through the use of retractable plates positioned below the piston during the end of the compression stroke. While the idea aims to facilitate constant volume heat addition, participants highlight that the piston head already provides an airtight seal, making it ineffective for altering chamber pressure. Alternative suggestions include using a contra piston to maintain volume during combustion and exploring the timing of combustion to achieve near-constant volume conditions. Ultimately, the feasibility of these concepts remains uncertain, with emphasis on engineering challenges and the need for further evaluation.
  • Understanding of diesel cycle thermal efficiency
  • Knowledge of piston-cylinder dynamics
  • Familiarity with combustion processes in internal combustion engines
  • Basic principles of mechanical engineering design
  • Research the principles of constant volume combustion in Otto and Diesel cycles
  • Explore the design and function of contra pistons in engine applications
  • Investigate the effects of combustion timing on engine efficiency
  • Learn about actuator technologies suitable for high-pressure environments in engines
Mechanical engineers, automotive engineers, and researchers focused on improving internal combustion engine efficiency and exploring innovative combustion techniques.
venkata
In case of diesel cycle thermal efficiency is low, because heat addition takes place at constant pressure.so can we introduce some retractable plate which sits below the piston during end of compression stroke,and retracts back after heat addition,thus providing constant volume heat addition and increasing efficiency.These plates can be controlled by sensors connected to ECU.Does this idea works out
You are studying mechanical engineering. That is certainly the right field of study for your interests. But you need to evaluate your own ideas.
Here's how to start the evaluation of your idea. Make a sketch showing your idea. Include some approximate dimensions, calculate how far each part needs to move, how much time is available to make the moves, the necessary accelerations and resulting forces. Show us actuators that provide those forces at those speeds. If you get stuck, show us how far you got, and we will help.
If I understand what you are suggesting, I believe this will not work. In a piston cylinder, the piston head provides an essentially air tight seal between the combustion chamber and the bottom portion of the bore. The heat addition (combustion) occurs at constant pressure because the cylinder is being driven down on the power stroke, thus changing the chamber volume. Any plates below the piston head would not affect the chamber pressure and therefore would not improve the efficiency. Keep thinking outside the box though!
So that's what I think,if we can place plates under piston head we could restrict the movement of piston and thus causing constant volume heat addition
What do you mean by plates under the piston head? Can you make a sketch?
Anything inserted into the cylinder to try and keep the volume constant would have to overcome the pressure in the cylinder. As far as I can see the power this would require is the same as that delivered to the piston.
Perhaps you could explode the fuel in a side chamber (of fixed volume) and then when it's fully burnt open a valve allowing the products of combustion into the cylinder head driving down the piston.
You might even be able to use the piston itself as the valve.
I'm sure there are disadvantages.
The piston is linked to the crankshaft of the engine by the piston rod and therefore it is in constant motion as the crankshaft rotates so it is not possible to arrest its reciprocating motion at any point in its stroke.
But in case of Otto cycle how could we achieve constant volume heat addition
See my post above.
Edit: Another method might be to use a contra piston in the head that was moved up and down in sympathy with the regular piston to keep the volume constant for a short period around combustion time.
The point is that it's likely to be possible, it's only engineering. The question is would it really make combustion more efficient?
It is an approximation.From whatever I was taught during college,as the piston moves towards the TDC from the middle of the stroke, it is decelerated and its velocity changes direction at the TDC.So for a very short time, the piston velocity will be zero.
Then the combustion process occurs so quickly that the piston would not have moved a lot during combustion.
By aligning these two factors(i.e. choosing the right time to start the combustion), an approximately constant volume heat addition is achieved.
Just as a comment: By the above theory, if constant volume expansion is more efficient; then, ignoring all other factors, an engine should be more efficient at lower rpm's because that maximizes the time during which the piston is transiting tdc, while the burn time is the same at all engine rpm's.
  • · Replies 47 ·
9K
  • · Replies 35 ·
  • · Replies 30 ·
