Difference Between Analog and Digital Technology
The discussion centers on the differences between analog and digital technology, particularly in the context of musical synthesizers. Participants explore how sound synthesis operates in both formats, touching on concepts such as frequency modulation and phase distortion synthesis, as well as the underlying principles of wave manipulation.
  • One participant notes that analog technology alters actual sound waves in real time, while digital technology approximates these waves and allows manipulation through software.
  • Another participant questions the meaning of "operated on actual waves in real time" and seeks clarification on oscillators and their function.
  • A participant explains that in analog systems, changes in circuit properties affect the sound signal, whereas digital systems create a virtual model of the analog signal, manipulate it, and convert it back to sound waves.
  • It is mentioned that analog data is represented by varying electric pulses, while digital data is represented in binary format with distinct amplitudes for each bit.
  • Several links to external articles are provided to further explain continuous and discrete signals, as well as quantization in signal processing.
Participants express varying degrees of understanding regarding the distinctions between analog and digital technologies, with some seeking clarification on specific terms and concepts. No consensus is reached on the definitions or implications of these technologies.
Participants reference specific technical terms and concepts that may require further exploration, such as oscillators and the nature of wave manipulation in both analog and digital contexts. The discussion reflects a mix of foundational knowledge and inquiries into more complex ideas.
modulus
A few days ago, I was reading an article on wikipedia about how musical synthesizers work and I read that initially analog technology was used and later digital technology began to be used.
What I uderstood from analog technology was that only one part of the sound was altered, which affected the sound produced as a whole. For example, we vary the frequency of the sound in such a way that it also changes the amplitude and the pitch, resulting in the emission of a completely new sound.
But, as I read ahead, I figured out that most modern synthesizers synthesize sounds through either 'FMS (Frequency Modulation Synthesis)' or 'PDS (Phase Distortion Synthesis)'. It told me that in FMS just by altering the frequency, we change the sound and in PDS it told me that just by altering the phase angle, the sound was synthesized. Yet, it called this form of synthesis digital technology.
I don't quite understand that, because isn't that the same thing as analog technology (we just alter one thing to synthesize the whole sound)?? So, what exactly is the difference between analog and digital technologies??
In case you need to check, this is the link of the article: http://en.wikipedia.org/wiki/Synthesizer
Any help will be appreciated. Thank you.
Analog technology operated on actual waves in real time. Digital technology approximates waves and has a layer of software that allows the user to manipulate them as if they were real waves.
Hmmmm... that kind of cleared things up, but, what do you mean by 'operated on actual waves in real time'. The article had something about oscillators... how do those work??
With analog the reason the noise changes is because you changed the properties of the circuit producing the signal. With digital you make a virtual model of a analog signal, manipulate it and then send it to your sound card to be converted from binary data into analog sound waves.
.. and by 'actual waves' I just mean physical. Waves are geometric ideas like circles, and anything real is quantized at some point, but they map to what is observed so well that it's just easier to think of them that way.
17K
