Difference between e/E and U in Ohm's law for receivers and generators
3 replies · 5K views · last reply
Mohamad&Issa
In ohm's law for a receiver or generator I couldn't understood the difference between e/E and U(voltage).
So please can anybody help me in this?
Hi M&I. The use of e, E, V, U, etc., to represent potential difference is a choice made by the author of a diagram or document. Sometimes the choice is personal preference or local convention, or sometimes it's just to avoid duplication if a given variable is already in use for something else.
No matter what variable name is used, all electric potential differences are treated the same way for analysis (Ohm's law, Kirchhoff's law, etc.).
Do you have a particular example where the naming is causing confusion?
In ohm's law for a generator:
U=E-r.I
U voltage
E electro motive force
r resistance
I current
And ohm's law for a receiver
U=e+r.I
e back electro motive force
U=E-r.I
U voltage
r resistance
I current
U=e+r.I
The U,E, and e are representing different potentials in a generator/motor situation. It seems that the author has decided to use U for the "line" potential, e for the back-emf created in the motor's windings (inductance), and E for the potential developed across a generator's windings. The naming convention is designed to help you keep track of what the values represent "in the real world".
Circuit schematic of a generator connected to a motor, each in a box, with a series resistor r_g and r_m and an inductor-like coil in each; a line current I flows between them, with labels E, e, U and Ir.
The figures in your text might show the inductor potentials as dependent voltage supplies.
  • Circuit schematic of a generator connected to a motor: each side has a winding labeled E (generator) and e (motor), a series resistor labeled r_g and r_m, a line current I with arrows marked Ir, and a line voltage U between the two boxes.
