Difference between gravitational and inertial mass
The discussion clarifies the distinction between inertial mass and gravitational mass, emphasizing that inertial mass, defined by Newton's Second Law (F=ma), measures an object's resistance to acceleration, while gravitational mass relates to the gravitational force experienced by an object (F=(GmM)/r^2). Inertial mass remains constant regardless of speed, whereas gravitational mass can vary due to changes in the gravitational field strength. The conversation also highlights the equivalence principle, which asserts that inertial mass and passive gravitational mass yield the same measurements under experimental conditions, a fact supported by Eötvös' experiments.
  • Understanding of Newton's Second Law (F=ma)
  • Familiarity with gravitational force equations (F=(GmM)/r^2)
  • Knowledge of the equivalence principle in physics
  • Basic concepts of mass types: inertial, active gravitational, and passive gravitational mass
  • Research the Eötvös experiment and its implications for mass equivalence
  • Explore the equivalence principle in detail, particularly in the context of general relativity
  • Study the differences between active and passive gravitational mass
  • Investigate the role of mass in gravitational field theory and its applications in astrophysics
Students of physics, educators, and anyone interested in understanding the fundamental concepts of mass and gravity, particularly in the context of classical mechanics and general relativity.
chipotleaway
I can't seem to get my head around the difference between the two.
Inertial mass appears in F=ma and is a measure of an object's resistance to acceleration when being acted upom by a force/s. Gravitational mass appears in F=(GmM)/r^2 - what 'role' does mass play here?
there's a huge difference...inertial mass is found from Newton's 2nd law..nd it deals when a body moves horizontally..it does not change with speed (provided its speed is very less than that of light)..
whereas gravitational mass is the ratio of weight of the body acceleration due to gravity..as the acceleration due to gravity is not same everywhere on earth..so it changes..
hope that helps..
Inertial mass resists forces, gravitational mass is a source of forces.
I'm not sure what dev70 meant by saying that gravitational mass changes, though. It doesn't.
Inertial mass is defined by Newton's Second Law: Force causes acceleration of an object, and the ratio of the force and the acceleration is constant for the object.
You can measure also the weight of an object. Imagine you have two objects with the same weight. Their material, shape, size might be different. Apply the same force on both. Will be their acceleration the same? Or will be the weight of two bodies of equal inertial masses the same? The answer is not straightforward. Gravity can act differently on bodies of different material. The equivalence of the two kinds of mass was subject of Eötvös' experiments, for example. http://en.wikipedia.org/wiki/Eötvös_experiment
ehild
well...i actually didnt mean it...mass remains same..but weight varies..that sounds better..thanks for pointing this out..
This is a source of confusion sometimes because there are actually two types of gravitational mass, active and passive. It's a pet peeve of mine when people use the term loosely without making it clear which one they're talking about. Passive gravitational mass is a measure of strength of a bodies interaction with a gravitational field. Active gravitational mass is a measure of strength of the gravitational field produced by a body. Usually the former is implied when the term "gravitational mass" is used by itself, but not always. And then sometimes people just simply get it wrong.
To give an example of what the differences are:
The inertial mass of your body could be determined by measuring how much force is required to accelerate yourself at a certain rate. Or in other words, Newton's second law.
The passive gravitational mass of your body could be determined by, well, simply standing on your bathroom scales.
The active gravitational mass of your body could be determined by using a torsion balance. And it would be a very delicate and difficult task. That's because the active gravitational mass of your body would be very small.
The equivalence principle tells us that the three methods of determining your body's mass, as described above, will give us the same result (within experimental error of course).
You may ask, how can active gravitational mass be equivalent to the other two types when I stated that it would be a very delicate and difficult task to measure in a human body. The answer is that the equivalence principle, as it applies to active gravitational mass, is a proportional equivalence and not a quantitative one.
@TurtleMeister
What do you mean by active gravitational mass of your body would be very small. Isn't that mass same as a passive mass, but the field generated by it would be small?
xAxis said:
@TurtleMeister
That's a good question. As I said, gravitational mass is a source of confusion. Sometimes it is described as the mass that produces the field, and sometimes it is described as a measure of the strength of the field itself.
Here is one definition from Wikipedia:
Active gravitational mass is a property of the mass of an object that produces a gravitational field in the space surrounding the object, and these gravitational fields govern large-scale structures in the Universe.
And here is another definition from the same Wikipedia page:
Active gravitational mass (* see below) is a measure of the strength of an object’s gravitational flux (gravitational flux is equal to the surface integral of gravitational field over an enclosing surface).
I myself just consider it to be the same thing as the standard gravitational parameter, which is defined by Kepler's third law.
ehild
Wow that's pretty unintuitive based on what I have learned so far. I guess I'm getting confusued because I feel like the mass of something determines how much it accelerates in response to a force and that same mass should also dictate the gravitational attraction between it and another mass.
There are a couple of things in ehild's post that you may have interpreted wrongly.
The equivalence of inertial mass and passive gravitational mass (what ehild is talking about) has been experimentally verified to better than one part in 1013. Proposed satellite experiments will extend that to one part in 1018.
I am assuming that ehild meant for this to be a question and not a statement, since it is followed up with a link to the Eotvos experiments. If it was meant as a statement then it is wrong (based on current theory and experimental evidence).
As explained above there are three types of mass in Newtonian mechanics:
inertial mass - That which gives movng objects momentum (Weyl's definition of inertial mass)
active gravitational mass - The source of a gravitational field
passive gravitational mass - That on which a gravitational field acts.
It's very important to keep these things in mind and to note the difference between them. When you get into general relativity its essential to know that inertial mass density is different than the density of active gravitational mass while being the same for passive gravitational mass.
I have not studied general relativity, except for an occasional excursion into the "Special & General Relativity" forum here at PF. Does this difference in mass density between Ma and (Mp, Mi) have a constant proportionality in GR?
No. And it's not always possible to provide a definite quantity in generality which one can call the mass density. Mass is fully described by a tensor.
Using units for which c = 1, and letting the source be an ideal gas then
active gravitational mass density = energy density + 3xPressure
while
inetial mass density = energy density + Pressure
I should point out that different people define these terms differently than above.
To further what Popper said, in GR the active gravitational mass essentially doesn't exist. In Newtonian gravity the active gravitational mass is the thing which acts as the source of gravity. In GR, the thing which acts as the source of gravity is the stress-energy tensor.
In a situation where Newtonian gravity is a good approximation to GR then you can make the simplification Popper mentioned.
I talked about classical mass. Each theory has got its own definitions and postulates. Classical physics postulated position, time, and interaction between objects. It also defined velocity and acceleration and Newton set up his laws. The second one is definition of the mass of an object: the inertial mass. There is also the weight of a body: you put a body on the scales and balance it with a standard "weight", then you say that the body has the weight equal to the standard one. That weight is proportional with the gravitational mass, as you balance the force of gravity. As inertial mass and gravitational mass were measured with different procedure, (one dynamic, the other static) it was not sure if they were really proportional or with properly chosen proportionality factor, were they identical. That was proved experimentally with very high accuracy since then, but the concepts themselves were not equivalent.
It was a question, the masses proved to be equal experimentally with high accuracy. So we take them the same when determining acceleration or when we determine the force a big load exerts on a support.
You can make different theories on different models. You can make a theory where mass is postulated itself and no distinction exists between gravitational and inertial mass.
When you define a physical quantity you have to make it clear, how is it measured. In SR, rest length (proper length) is measured by comparing it with a metre stick, while you measure length with a different procedure from a moving frame of reference. The different measurement procedures result in different numerical values for the length of the same object.
The same with mass - rest mass is different from the moving mass.
And you can speculate what is mass, if it exist at all? ...
ehild
The distinction between active and passive gravitational mass are attributed to the approximation of the gravitational interaction with the help of "gravitational field". That is a proper approximation when the motion of one of the interacting bodies (the big one) is not influenced by the motion of the "small" body. It is said then, that a gravitational field exist around the big body, determined by its (active) mass. The intensity of this field multiplied by the (passive) mass of the small body is equal to the force acting on the small body, and that force determines its acceleration if divided by the (inertial) mass. That is an approximation which fails when the masses of the bodies are comparable. In case of a pair of twin stars, you can apply the law of gravity to figure out the motion of both starts, but you can not use the gravitational field approximation.
ehild
to the OP post I could use a gyroscope as an answer and a working model where inertial mass or the physical rotation of a given "mass" wheel counteracts the force exerted on the wheel by gravitational mass , by the way everyone can try to spin a bicycle rim and then try to move it in different angles while it spins.
@Popper or DaleSpam
Do you mean to say that in a situation where Newtonian gravity is a good approximation to GR that the stress-energy tensor will not necessarily be proportional to Mi and Mp? If this is true then how does the equivalence principle apply to GR?
Classical physics has changed over time. New terms and concepts are incorporated. For example, prior to the twentieth century the concept of mass being divided into the three types that we are discussing, did not exist.1 Or at least there is no written record of it. In your post #4, you stated:
emphasis mine
This refers to the equivalence of inertial mass and passive gravitational mass based on material composition. The experimental verifications that I mentioned are for the torsion balance experiments done by the Eot-Wash Group and the proposed satellite experiment called STEP. These experiments are just more modern versions of the Eotvos experiments that you linked to in your post.
1Even though the concepts did not exist prior to the twentieth century, experiments involving them did, as evidenced by Newton's pendulum experiments using bobs made of various materials.
there is no difference between inertial and gravitational mass; however, how it is measured is the difference
Why not using the passive gravitational mass of Earth to measure your active gravitational mass? That could be done by, well, simply standing on your bathroom scales.
There is no difference.
It can be any direction.
The attractive force decreases as distance between the masses increases. The masses don't change.
ehild
This is a bit confuseing, have you read the link you posted.From it I came to the conclusion that bodies of different materials act the same when gravity acts upon them.
As the experimental devices get more refined with time, the differences between the results of the different materials used, get less and less.
It appears to be a case of experimental error and refinement
No, it's not that simple. The term active gravitational mass is somewhat of a misnomer because it's not really mass at all, it's a property of mass. It's a measure of the strength of a body's gravitational field. It is the same thing as the standard gravitational parameter and has the units of m3s-2. It cannot be measured with bathroom scales. It can however be measured by a torsion balance, or if you're talking about a planet or moon, then it can be measured by using an orbiting satellite and applying Kepler's third law.
I have answered this question in good faith, believing it to be in line with current mainstream ideas.
To my knowledge the strength of the gravitational field is measured in units of m/s² (e.g. round about 9.8 m/s² for the gravitational field of Earth at sea level).
In classical mechanics (and that's what we are talking about) the strength of a gravitational field can be determined by measuring the force acting on a body with known passive gravitational mass and the force acting on Earth within your gravitational field can be measured with bathroom scales.
What makes a torsion balance more appropriate than bathroom scales?
That's the field strength right here at the Earth's surface. If you want a single number that reflects the overall gravitational field of the earth, you do not want that number to depend on where you took the measurement.
Gravity follows an inverse square law. So you have to multiply the measured local acceleration by the square of the radius where you took the measurement to arrive at the standard value for the field strength. That result should match Newton's universal gravitational constant (big G) times the mass of the earth.
See "The GM Product" on http://en.wikipedia.org/wiki/Gravitational_constant.
OK, that wuld mean I need the passive gravitational mass and the radius of Earth to measure my active gravitational mass using bathroom scales.
First off, you have the sense of "passive" and "active" backwards. More on this later.
Your bathroom scale does not measure gravitational force. There is no local experiment that can measure gravitational force. A spring scale is a kind of a local experiment. What a spring scale measures is the upward normal force exerted by the scale on you. Since you are standing still on the scale, you can use that measurable upward normal force as a stand-in for gravitational force. Suppose you take that scale on a zero g airplane ride and use it to weigh yourself. You will notice that what the scale registers varies a lot even though the gravitational force only changes by a tiny amount as the plane climbs and dives.
The distinction between active and passive gravitational mass.
A bathroom scale indirectly measures the Earth's gravitational force on you. Here it's the Earth that is the active gravitational body and you are the passive body. Suppose you connect a small test mass to an extremely sensitive spring and place that test mass near you. The test mass will feel a feeble gravitational attraction toward you. Now you are the active gravitational body and the test mass is the passive one.
Note very well: The distinction between inertial mass, passive gravitational mass, and active gravitational mass borders on fringe physics. There is no distinction whatsoever between the three concepts in Newtonian mechanics. That inertial mass and passive gravitational mass are one and the same is also a central tenet of general relativity.
What about active gravitation mass? That gets very tricky in general relativity because of nonlinearities in the theory. Gravity begets gravity: http://www.einstein-online.info/spotlights/gravity_of_gravity. Einstein was very careful in developing his equivalence principle to avoid these nonlinearities. That's why he wrote about test masses (very small masses) that steer clear from those nonlinear behaviors.
That's sufficient.
And vice versa.
Here again both bodies are active and passive at once. I am also attracted toward the test mass. Everything else would be a violation of the third law.
There is a distinction between inertial and gravitational mass but Newton assumed them to be equal due to corresponding experimental results. But you are right in regard to active and passive gravitational mass. There is nothing like that in the original definition of Newtons law of gravitation. Even the mathematical formula shows that both masses play the same role.
There is no such thing like gravitational mass in GR. Transferring the results of GR back to classical mechanic shows that the weak equivalence principle is valid for bodies at rest only. At relativistic velocities happens something like this: http://home.comcast.net/~peter.m.brown/ref/mass_articles/Olson_Guarino_1985.pdf
As I already wrote above there is no gravitational mass in GR. In GR the source of gravitation is the stress-energy-tensor. Gravitational mass is used in Newtons law of gravitation only. That's why I pointed out above that this discussion is about classical mechanics only.
It was Einstein who said that inertial and gravitational mass are equal in his equivalence principle. Where do you find a distinction between the two? The link you provided does not work.
Einstein said in his equivalence principle that gravitation and inertia are equivalent. That means that you cannot distinguish between a frame of reference resting in a homogeneous gravitational field from an accelerating frame of reference. There are a lot of other wordings (e.g. equivalence between classical inertial systems and locally free falling systems or same trajectory for all bodies starting from the same point with the same velocity in a static gravitational field) but it is not identical with the weak equivalence principle. The equivalence of inertial and gravitational mass results from Einsteins equivalence principle for bodies at rest but not for bodies moving at relativistic velocities.
The first distinction can be found in Newton's Philosophiae Naturalis Principia Mathematica as a comment to his definition of "quantity of matter" (Definition 1):
"And the same [quantity of matter] is known by the weight of each body; for it is proportional to the weight, as I have found by experiments on pendulums, very accurately made, which shall be shewn hereafter."
Newton clearly distinguished between weight and inertia but assumed them to be proportional due to corresponding experimental results. (I think he actually did it to keep the Galileian equivalence principle.) In classical mechanic there is no theoretical explanation for this proportionality. Even GR gives an explanation for bodies at rest only.
Olson DW, Guarino RC. Measuring the active gravitational mass of a moving object. American Journal of Physics. July 1985. 53(7):661-3
  • · Replies 18 ·
  • · Replies 22 ·
