Studiot said:
This is not the same statement as the original, and unfortunately it is even more unsatisfactory.
rewriting it as a an equation inertia = momentum/rate of change of motion
leads to division by zero in the case of a particle or system at rest.
I'm about to be sarcastic but please take it in proper friendly humor...
[begin sarcasm]
Yea, it's a shame we don't have some kind of mathematical thingy... let's call it, oh,
a limit which has some way of dealing with indeterminate forms. It would be great we could create a whole mathematics using it, since it would let us calculate things we could call it, something like, oh I don't know,
calculus.
Yea! If only we had that then we could actually even define what we mean by instantaneous velocity! But it's a shame we don't so that displacement over interval of time is undefined when considered at an instant. Instantaneous
velocity, and
acceleration, and
power, and so on are just badly defined concepts. And don't get me started on
integrals!
[end sarcasm]
In all seriousness, I find your objection without merit. We can define velocity as the relationship between displacement and duration... displacement = duration times velocity...
velocity = displacement/duration. We can take the limit as the duration goes to zero and be precise about instantaneous velocity when that relationship is time dependent. Your objections fall flat.
Studiot said:
You might call it the moment of inertia tensor...
I call it the inertia tensor.
That is because , in general, it contains terms other than moments of inertia.
You can call it "pixilated" if you like but it is called the
http://en.wikipedia.org/wiki/Moment_of_inertia#Moment_of_inertia_tensor" in the textbooks.
Those other terms are still http://en.wikipedia.org/wiki/Moment_(mathematics)" of the mass distribution. (mass density being a perfectly good example of a general
measure or
distribution as those terms are used in mathematics.)
The tensor as a whole is the natural generalization, to vector-tensor forms, of the component moment of inertia in that it's the thingy you multiply the angular velocity by to get the other thingy called angular momentum.
If you want to shorten the name for brevity's sake then that is all fine and good. But I don't think anyone is interested in your choice of abbreviation if that is the case.
Anything you say about components is basis dependent. The elegant and correct statements (which thus also provide good intuition when understood) should be expressed independent of bases. That is especially important in this case where we are trying to clarify for the OP the physical meaning of quantities.
