Difference between these equations?
  • Level: High School
  • Thread starter STEMucator
    Difference
Homework Helper
I've been curious about this for awhile. What's the difference between the following two equations:
##(1) v_2 = v_1 + a \Delta t##
##(2) v_2^2 = v_1^2 + 2a \Delta d##
My hunch is that ##(1)## represents the final speed in a non-parabolic scenario while ##(2)## is used when the object travels in an arc.
I was curious about this because the two equations won't produce the same answer when asked to find the "final velocity" of an object.
2 is used when an object travels in a straight line.Let's put it this way
##v=u+at##
##v^2=u^2+2as## (v= final velocity,u = initial velocity)
First equation is just a rearrange of acceleration equation which is
##a=\frac{v-u}{t}##
The second equation is formed by combining the equations
##s=\frac{1}{2}(u+v)t## and ##v=u+at## (First equation)
These equations are known as Equations of motion.
Each equation has one quantity absent,in equation 1,it's s
In equation 2,It's t.
Yes,the two equations looks similar,because it's subject is v.However,two equations have different quantities.
If for example,u= 0. v= 10m/s .a= 2
Then time taken is 5 sec
and distance traveled is 25m.
What's the problem in this?Does this look similar?Does distance and time look similar?Note:s is displacement,v and u is velocity.They are not distance and speed
All the equations of motion applies if acceleration is uniform and object move in a straight line
But they do produce the same answer and they both apply to uniformly accelerated motion.
