Difference between two formulas of resistance
The discussion clarifies the difference between two resistance formulas: R=pl/A, which calculates resistance based on the physical properties of a wire, and V=IR, known as Ohm's Law, used for current flow in a circuit. The first formula is applicable for determining resistance from material properties, while the second is used when current is flowing through a resistor. It is emphasized that both formulas can be applied to the same problem; the first to find resistance and the second to find current when a voltage is applied. However, temperature changes, such as those affecting a light bulb filament, can alter resistivity, necessitating updated values for accurate calculations. Understanding these formulas is crucial for designing circuits and resistors effectively.
Coco12
There are two formulas for resistance
R=pl/A
V=IR
What is the difference between them?
Question b on the sheet. Why can you not use that data to calculate current flow when connected to a power source. I suspect it has something to Do with the difference between these two formulas.
R=pl/A
V=IR
What do the variables in those equations stand for?
When would you use the first equation to calculate resistance?
When would you use the second equation?
The first formula is just talking about the resistance of a wire the second is when there's a current flowing?
You didn't answer my first question. Defining the variables will help you to determine when you use each formula...
Ok I understand it now . I know the first equation has is resistivity * length divided by area
The second is volt = current * resistance
Therefore you use the second equation when there is a current
Yeah, the 2nd equation is Ohm's Law, and you use it when you know two of the 3 variables. The first equation is for calculating the resistance of some known geometry or volume (like a wire of known thickness, etc.).
No, it doesn't have to do with the "difference". They can actually be applied for the same problem. You can use one to calculate the resistance of the wire from the parameters of the wire and then use the second to calculate current when some given voltage is applied.
The key here is the mention of "cold filament".
How is the filament of a light bulb when powered at the nominal voltage?
The first formula relates the physical properties of the material the resistor is made of to it's electrical resistance. It's mainly used when designing a resistor.
The second is Ohms law. It applies to any resistor (that approximates the ideal) regardless of the material it's made of. It's mainly used when designing a circuit containing a resistor.
PS: There are other equations involving resistance. Nothing particularly special about those two.
For example
The power dissipated in a resistor is given by..
Power = I2R
where I = current.
cold filament means...? How does that relate?
Is the filament of a functioning bulb cold?
What happen with the resistance of a metallic wire when the temperature changes?
Did you learn about temperature dependence of rezistivity?
Oh yes. When the temperature increases the resistance increases
So if is a cold filament then you cannot use the other formula?
No, it's nothing about formula. They say that you cannot use these data. No mention about formula.
In order to calculate the current you will need both formulas. You use one of them to calculate the resistance of the filament, by using the dimensions and the resistivity. And then use Ohm's law to calculate the current, given the resistance found in step 1 and the voltage of 120 V.
BUT, these values are measured at room temperature.
When connected to 120 V, the filament heats up to about 2000 K.
At this temperature the rezistivity (as well as the dimensions) will have significantly different values.
So you will need those new values (as well as BOTH formulas) to calculate the current for hot filament.
Coco -- please check your PMs about your use of text speak (which I have been correcting)
Re my post above...
In the first formula the resistivity of the material is measured at one particular temperature, typically room temperature. What happens when power is applied?
