Different results with quotient rule
  • Thread starter Thread starter mike82140
    quotient
8 replies · 2K views
mike82140
I have been trying to figure out the derivative of (X²-1)/X. When I use the quotient rule, the result I get is 1-1/X². However, when I simplify the expression first, then take the derivative, I get 1+1/X²
Why are the results different?
Hypersphere said:
I get the same answer using both methods. Are you sure you include all terms in the quotient rule? http://en.wikipedia.org/wiki/Quotient_rule
Can you show how you evaluate it? I tried both ways, but get different results.
Alright, for a function
[tex]f(x) = \frac{g(x)}{h(x)}[/tex]
the quotient rule says
[tex]f'(x) = \frac{g'(x)h(x)-g(x)h'(x)}{h^2(x)}[/tex]
In your case, [itex]g(x)=x^2-1[/itex] and [itex]h(x)=x[/itex]. Thus [itex]g'(x)=2x[/itex] and [itex]h'(x)=1[/itex]. Then you get
[tex]\frac{\mathrm{d}}{\mathrm{dx}}\frac{x^2-1}{x}=\frac{2x\cdot x - \left( x^2 -1 \right) \cdot 1}{x^2}=\frac{2x^2-x^2+1}{x^2}=1+\frac{1}{x^2}[/tex]
Are you sure you included the [itex]g'(x)[/itex] term?
Simplifying first,
[tex]\frac{\mathrm{d}}{\mathrm{dx}}\frac{x^2-1}{x} = \frac{\mathrm{d}}{\mathrm{dx}} \left( x - \frac{1}{x} \right) = 1- \frac{-1}{x^2}=1+\frac{1}{x^2}[/tex]
Where did +1 come from when you were multiplying x²-1 with 1?
It was also multiplied by -1, from the quotient rule formula.
I'm sorry for asking so many questions, and this may sound stupid, but, what -1?
Edit: It appears as though I have made a mistake. The -1 is the minus part that is in front of the x²-1, so the negative, or minus, distributes itself.
Thank you for the help, I appreciate it.
You see the minus sign in front of [itex]\left( x^2 -1 \right) \cdot 1[/itex], right? That is just short notation for
[tex]- \left( x^2 -1 \right) \cdot 1=\left( -1 \right) \cdot \left( x^2 -1 \right)= (-1) \cdot x^2 + (-1) \cdot (-1) = -x^2+1[/tex]
Agreed? Or are you pulling my leg here?
EDIT: Ah, good. I was almost giving up for a while there.
Look at the formula for the quotient rule.
If h(x) = x, what is h'(x)?
