Different results with quotient rule
  • Thread starter Thread starter mike82140
    quotient
The discussion revolves around finding the derivative of the function (X²-1)/X using the quotient rule and comparing it to the derivative obtained by simplifying the expression first. Participants are exploring the discrepancies in results from different methods of differentiation.
  • Mathematical reasoning, Assumption checking
  • The original poster attempts to apply the quotient rule and simplify the expression before differentiation, leading to different results. Some participants question whether all terms were included in the application of the quotient rule. Others seek clarification on specific steps in the differentiation process.
Participants are actively engaging with each other's reasoning and attempting to clarify misunderstandings. Some have provided guidance on the correct application of the quotient rule, while others are exploring the implications of simplifications made prior to differentiation.
There are indications of confusion regarding the application of the quotient rule and the distribution of negative signs in the calculations. Participants are also reflecting on their own mistakes and seeking reassurance about their understanding of the differentiation process.
mike82140
I have been trying to figure out the derivative of (X²-1)/X. When I use the quotient rule, the result I get is 1-1/X². However, when I simplify the expression first, then take the derivative, I get 1+1/X²
Why are the results different?
Hypersphere said:
I get the same answer using both methods. Are you sure you include all terms in the quotient rule? http://en.wikipedia.org/wiki/Quotient_rule
Can you show how you evaluate it? I tried both ways, but get different results.
Alright, for a function
[tex]f(x) = \frac{g(x)}{h(x)}[/tex]
the quotient rule says
[tex]f'(x) = \frac{g'(x)h(x)-g(x)h'(x)}{h^2(x)}[/tex]
In your case, [itex]g(x)=x^2-1[/itex] and [itex]h(x)=x[/itex]. Thus [itex]g'(x)=2x[/itex] and [itex]h'(x)=1[/itex]. Then you get
[tex]\frac{\mathrm{d}}{\mathrm{dx}}\frac{x^2-1}{x}=\frac{2x\cdot x - \left( x^2 -1 \right) \cdot 1}{x^2}=\frac{2x^2-x^2+1}{x^2}=1+\frac{1}{x^2}[/tex]
Are you sure you included the [itex]g'(x)[/itex] term?
Simplifying first,
[tex]\frac{\mathrm{d}}{\mathrm{dx}}\frac{x^2-1}{x} = \frac{\mathrm{d}}{\mathrm{dx}} \left( x - \frac{1}{x} \right) = 1- \frac{-1}{x^2}=1+\frac{1}{x^2}[/tex]
Where did +1 come from when you were multiplying x²-1 with 1?
It was also multiplied by -1, from the quotient rule formula.
I'm sorry for asking so many questions, and this may sound stupid, but, what -1?
Edit: It appears as though I have made a mistake. The -1 is the minus part that is in front of the x²-1, so the negative, or minus, distributes itself.
Thank you for the help, I appreciate it.
You see the minus sign in front of [itex]\left( x^2 -1 \right) \cdot 1[/itex], right? That is just short notation for
[tex]- \left( x^2 -1 \right) \cdot 1=\left( -1 \right) \cdot \left( x^2 -1 \right)= (-1) \cdot x^2 + (-1) \cdot (-1) = -x^2+1[/tex]
Agreed? Or are you pulling my leg here?
EDIT: Ah, good. I was almost giving up for a while there.
Look at the formula for the quotient rule.
If h(x) = x, what is h'(x)?
  • · Replies 25 ·
