Different values with rotational kinematic equations
2 replies · 3K views
JinM
[SOLVED] Different values with rotational kinematic equations
Hello everyone,
I got two different values for final angular speed when I tried to use the third and fourth kinematic equations. I filled the template here with the problem with my attempts.
A bicycle wheel of radius r = 1.5 m starts from rest and rolls 100 m without slipping in 30 s. Assuming that the angular acceleration of the wheel given above was constant, calculate: a) The angular acceleration, b) the final angular velocity c) the tangential velocity and tangential acceleration of a point on the rim after one revolution.
Given
[tex]\Delta\theta = 100/1.5 = 66.7[/tex] rad
[tex]\omega_{i} = 0[/tex]
[tex]\Delta t = 30 s[/tex]
[tex]\alpha[/tex] is constant
Unknowns
[tex]\alpha = ?[/tex]
[tex]\omega = ?[/tex]
[tex]v_{t} = ?[/tex] and [tex]a_{t} = ?[/tex] when [tex]\Delta\theta = 2\pi[/tex]
[tex]\Delta\theta = \frac{1}{2} (\omega_{f} + \omega_{i}) \Delta t[/tex]
[tex]\omega_{f}^{2} = \omega_{i}^2 + 2 \alpha \Delta \theta[/tex]
[tex]\omega_{f} = \omega_{i} + \alpha \Delta t[/tex]
Part b:
[tex]66.7 = \frac{1}{2}(0 + \omega_{f})(30)[/tex]
[tex]\omega_{f} = 4.45[/tex] rad/s
Part a:
[tex]4.45 = 0 + 30\alpha[/tex]
[tex]\alpha = 0.15[/tex] rad/s^2
Part c:
My strategy is to find the final angular velocity [tex]\omega_f[/tex] using the first relevant equation. Then finding the tangential velocity by multiplying [tex]\omega_f[/tex] with the radius.
[tex]2\pi = \frac{1}{2} (\omega_{f} + 0)(30)[/tex]
[tex]\omega_{f} = \frac{2\pi}{15} = 0.419[/tex]
And then:
[tex]v_{t} = r\omega = (1.5)(0.419) = 0.6285[/tex] m/s
[tex]a_{t} = r\alpha = (1.5)(0.15) = 0.255[/tex] m/s^2However, the solution key has a different answer. [tex]\omega_{f}[/tex] after one revolution equals 1.37 rad/s and [tex]v_{t}[/tex] = 2.06. Apparently, they used this equation:
[tex]\omega_{f}^{2} = \omega_{i}^2 + 2 \alpha \Delta \theta[/tex]I'm a little confused. I double checked my calculations, and I am almost sure that I haven't made a calculation error. I appreciate it if someone could help me with this.
Thanks,
Jin
JinM;1573793- 2[tex said:
\pi[/tex] = 1/2 * (0 + [tex]\omega[/tex]f) * 30
Your mistake is assuming that the time here is 30 seconds. It takes quite a bit less than 30 seconds for the wheel to make one revolution.
OH! I get it now. Thanks a lot, D H
