Different ways to calculate force, GPE
  • Thread starter Thread starter physicsman7
    Force Gpe
Different methods exist to calculate force, gravitational potential energy (GPE), mass, and separation distance. Common formulas include F = ma for force, Fg = mg for gravitational force, and GPE = mgh for potential energy. Mass can be derived from kinetic energy or net force equations. Separation distance can be determined by rearranging formulas to solve for r based on known variables. Clarification on specific needs for alternative calculations would enhance the discussion.
physicsman7
Different ways to calculate force, GPE...
Different ways to calculate force,mass,Gravational Potienal Energy,seperation distance
Not sure how to find new ways to calculare these other than the already known formulas like
G(m1)(m2)/r^2
G(m1)(m2)/r^2
We shall be glad if you state clearly what exactly you want.
I want to know a diffrenet formula that can be used to caluclate those things
Well, all of these can be found many ways, and it's kind of unclear what you want.
For example:
\Sigma F = ma gets you the force if you have mass and acceleration.
Fg=mg gives you the force on an object due to gravity.
E=\frac{k q_1 q_2}{r^2} gives you the electric field (which is a force)
F_g=\frac{g M m}{r^2} is the general force of gravity.
and there are many more.
Mass can be calculated from lots of things, assuming you know other variables--kinetic energy, certain potential energies, certain forces, net force, etc.
GPE can be found using the generic equation U_g=-\frac{g M m}{r}, by total energy minus everything that's not GPE, Ug=mgh, integrating force, etc
Separation distance (if I am interpreting it correctly) can be found by knowing the result of most of the equations I have already listed and solving for r and other ways.
thanks, sorry I am also a little unclear withe question is as well it wants to know new ways to calculate all those things that's all it says but thanks for the help
