Differential equation for draining a pool
The discussion revolves around a differential equation related to the draining of a pool, specifically focusing on the setup of the equation, equilibrium solutions, and conditions for the pool to overflow or empty. Participants explore various aspects of the problem, including mathematical formulations and interpretations of the conditions given in the problem statement.
  • One participant expresses confusion about the problem statement, particularly regarding part (c) and the setup of the differential equation.
  • Another participant corrects an earlier claim about the flow rates and provides a substitution into the differential equation, leading to a new formulation.
  • A participant identifies the equilibrium solution as \(D = k^2\) and discusses its stability based on the behavior of \(dD/dt\) around this point.
  • There is a discussion about the implications of the equilibrium point in relation to the pool's overflow and emptying conditions, with one participant suggesting that for \(k > 2\), the pool will overflow, while for \(0 \leq k < 2\), it will empty.
  • Another participant elaborates that for the pool to completely empty, \(k\) must equal zero, emphasizing the relationship between the inflow and outflow rates.
Participants generally agree on the equilibrium point and its stability, but there is some uncertainty regarding the specific values of \(k\) that lead to the pool overflowing or emptying. Multiple views on the conditions for these scenarios are presented, indicating that the discussion remains somewhat unresolved.
Some participants express confusion over the initial conditions and the role of \(D_0\) in the equations, highlighting potential limitations in the problem's setup and the assumptions made about the inflow and outflow rates.
Vishak95
Hi MHB. Can someone help me with this one please? I don't understand what the question is really saying...in particular part (c).
I tried to set up dD/dt = k - D^1/2 but it doesn't seem correct. Thanks.
I have moved this topic to our Differential Equations sub-forum, as it is a better fit.
Your answer to part (a) is not quite correct. We know:
(1) $$\frac{dV}{dt}=\text{flow in}-\text{flow out}$$
We are given:
$$V=100D,\,\text{flow in}=k,\,\text{flow out}=\sqrt{D}$$
So, substituting these given values into (1), what do we obtain?
Ok, now I've got this:
$$\frac{dV}{dD}= 100$$
$$\frac{dV}{dt} = \frac{dV}{dD}\cdot \frac{dD}{dt}$$
Leading to:
$$\frac{dD}{dt}= \frac{k-\sqrt{D}}{100}$$
Looks good. :D
Okay, thanks :)
So now for part (b) I've got the only equilibrium solution:
$$D = k^{2}$$
Which is stable.
But I'm completely lost looking at part (c) :(
Your equilibrium point is correct, and is stable since:
i) For $$D<k^2$$ we have:
$$\frac{dD}{dt}>0$$
ii) For $$D>k^2$$ we have:
$$\frac{dD}{dt}<0$$
which shows that for all values of $D$, we must have:
$$\lim_{t\to\infty}D(t)=k^2$$
So, for part (c) you want to look at what values of $k$ cause the equilibrium point to satisfy the condition that the pool overflows or empties. Where would these equilibrium points be?
Ok, thanks.
The thing that's still tripping me up is this part:
$$D_{0} \in (0,4)$$
And the fact that right now D0 isn't in the equation...
Vishak said:
Ok, thanks.
$$D_{0} \in (0,4)$$
$$D_0=D(0)$$
and we are given that:
$$0<D_0<4$$
Can you now state what values of $k$ will cause the pool to empty and overflow?
I'm guessing that for k > 2, it will overflow and for 0 <or= k < 2 it will empty?
You are correct that for $2<k$ the pool will overflow, since the equilibrium point will be greater than the depth of the pool.
In order for the pool to empty, we require the equilibrium point to be $D=0$, so we require $k=0$.
In other words, in order for the pool to completely empty, there can be no water flowing into the pool, given that the initial amount of water is greater than zero. If there is any water flowing into the pool, no matter how slowly, then the equilibrium point will be greater than zero. Because the rate at which the water leaks out varies as the square root of the depth, as the level of the water decreases, the rate at which it leaks out will decreases as well, until at some point the rate at which it leaks approaches the rate at which it is being pumped in, and we approach equilibrium.
Thank you so much for that explanation! I understand it now :)
  • · Replies 52 ·
10K
  • · Replies 25 ·
