Differential equation (product/quotient)
4 replies · 3K views · last reply
recoil33
I have several questions, so i'll post these as i go.
1.
y = (5x+2)2/((x+5)3)2
u = (5x+2)2
u' = 7(5x+3)6 . (5)
v = (x+5)3
v' = (3(x+5)2).(1)
Quotient = (u(x)*v'(x) - v(x)* u'(x) / v(x)2)
(5x+2)7 . 3(x+5)2 - (x+5)3 . 7(5x+5)6 .(5) / ((x+5)3)2
[ If i knew how to put this under i would ]
What have i done wrong here? not exactly sure ;s
__________________________________________________________________________
2.
If i have an equation with 2 brackets on the numerator, and only 1 on the denominator will i use the product rule for the numerator then the quotient? Or, will i expand the brackets then use the quotient rule?
Example:
(4x+9)(6x+1) / (8x+3)
u = (4x+9)(6x+1)
u' = (4x+9)(6) + (6x+1)(4)
v = (8x+3)
v' = (8)
Am i doing the right thing here? Any advice will help thank you.
[If my question is not clear please tell me]
Thanks in advance, recoil33
recoil33 said:
u = (5x+2)2
u' = 7(5x+3)6 . (5)
I'm assuming there's a typo-- [itex]u=(5x+2)^{7}[/itex], right?
The quotient rule is [tex](u'(x)*v(x)-u(x)*v'(x))\over (v(x))^{2}[/tex]; you reversed the order of differentiation. You take the derivative of the function in the numerator first.
You can do it either way. The work you posted is correct.
@ JThompson
Yes, the equation was sapose to be
u = (5x +2)7
u' = 7(5x+2)6
The equation will be incorrect if i accidently put u'(x)*v(x) and v'(x)*u(x) in the wrong order?
@Hallsofivy
Sorry, bit new to the terminology of the mathematics.
I guess it's not a differential equation?, although was it in the right section? (calc and beyond)
Thanks JThomas for your help and thanks for your input ivy ;)
Yes. The derivative will be of the opposite sign.
v'(x)*u(x)-u'(x)*v(x)= -(u'(x)*v(x)-v'(x)u(x))
Good luck.
