How Can Phasors Represent the Function g(t) in Complex Form?
The discussion focuses on representing the function g(t) = a cos(ωt) + b sin(ωt) in complex form using phasors. The key takeaway is that g(t) can be expressed as the real part of the complex function keiΦeiωt, where k and Φ are the amplitude and phase, respectively. Participants emphasize the importance of Euler's formula, eiωt = cos(ωt) + i sin(ωt), to derive the necessary relationships between the coefficients a, b, k, and Φ. The conversation highlights the need to equate the real parts of both expressions to find the values of k and Φ that satisfy the equation.
  • Understanding of complex numbers and phasors
  • Familiarity with Euler's formula
  • Knowledge of trigonometric identities
  • Ability to manipulate algebraic expressions
  • Study the derivation of phasors in electrical engineering contexts
  • Learn how to apply Euler's formula in different scenarios
  • Explore the relationship between amplitude and phase in sinusoidal functions
  • Investigate the use of complex numbers in signal processing
Students studying electrical engineering, physics, or mathematics, particularly those focusing on wave functions and signal analysis.
Dusty912
Given a function g(t)=acosωt + bsinωt, where a and b are constants, show that g(t) is the real part of the complex function: keeiωt for some k and Φ
Remark: the complex expression ke is called a phasor. If we know that g(t) has the form kcos(ωt+Φ) then we need know only the constants k and Φ-the amplitude and the phase- to know the function g. Hence we can use the phasor ke as a notation for the function g(t)=keeiωt
Euler's formula eiωt= cosωt +isinωt
Not really sure where to start here except for expanding using euler;s as the first step. any help would be greatly appreciated.
So do that, for both exponential terms.
okay so then I get k(cosΦt +isinΦt)(cosωt+isinωt)
but what should this be equal too?
How do you get φt terms?
umm I'm not sure. I didn't know we would be using that symbol. What does φ represent?
It is a constant. You need to find the values of k and φ which make the real part match g().
I think perhaps you did not understand my question. In your post #3, you had terms like sin(φt). I don't understand how you got those. Please post your working.
Sorry I'm kind of lost. Where did φ come from?
In my third post I only haveΦ k ω and t
no φ
Dusty912 said:
no φ
Looks like a font issue. Are you saying Φ and φ look very different to you? In the font that comes up on my iPad they are almost the same, so I may have used the wrong one.
yes they look very different. I think that's where the confusion was.
Ok, so please reread my posts with that in mind.
But in regards to your earlier quastion. I used euler's formula to obtain sin(Φt) eiΦt=cosΦt +isin(Φt)
right?
that sin (Φt) is not apart of that calculation
right?
According to your initial post, it is e, not eiφt.
oops, my mistake, than diregard the t's
Ok. So multiply out the corrected version of the expression in your post #3.
k(cosΦ +isinΦ)(cosω+isinω)
No, the other exponential term does have a t factor: eiωt.
k(cosΦ +isinΦ)(cosωt+isinωt)
Right. Now multiply out.
kcosΦcosωt +kisinΦcosωt + kisinωtcosΦ -ksinΦsinωt
Right. What part of that is relevant in this question?
The part that does not have i's in them? the real parts
Yes. What values of k and φ make the real part match g?
i'm not sure I want to say 0 or π/2 for Φ but that doesn't seem right.
Remember that t is a variable, so the functions are to produce the same value for every value of t. This means that the cos(ωt) term must look the sameinboth functions, and the sin term must look the same too. That givesyou two equations for the coefficients.
well if I equate this to g(t)=acosωt+bsinωt than I would get Φ=π/2 and b for the sin's and Φ=0 and a for the cos's or is my algebra wrong on this?
ωT)
Compare the expression for g with the real part of the complex expression in post #23. Look at the two cos(ωt) terms. If they are to be exactly the same, they must have the same coefficient. That gives you an equation relating a and b to k and φ. Do the same with the two sin(ωt) terms.
  • · Replies 28 ·
