Differential equation reducible to Bessel's Equation
9 replies · 27K views
joel19
How do I reduce an equation to Bessel's equation and find a general solution to it:
For example how do I solve this:
x^2y" + xy' + (4x^4 - 1/4)y = 0 (set x^2 = z)
Okay, apparently you have been told to "set z= x2". Have you tried that at all? Do you know how to use the chain rule to convert d2y/dx2 to d2y/dz2?
To start you off, dy/dx= (dy/dz)(dz/dx)= (2x)(dy/dz).
Then d^2y/dx^2= d(2x dy/dz)/dx= 2 dy/dz+ d(dy/dx)/dx= 2 dy/dz +(d^2y/dz^2)(2x).
Hi all,
How do i reduce the eqn. below to Bessel's eqn. (how can i use the transformation when i have y, x, and u)
4x^2y'' - 20xy' + (4x^2 + 35)y = 0 (y = (x^3).u)
Do you mean to set y= x3u(x) where u is some unknown function? Then just DO it!
If y= x3u, then y'= 3x2u+ x3u' and y"= 6xu+ 6x2u'+ x3u". Replace y, y' and y" in the equation with those and you get another differential equation for u rather than y.
I was not sure about u is a function of x, should that be so? I am asking this is because i do not understand (unless u is a func. of x) why we use a third variable for reducing.
I will try what you suggested, and thank you for your help.
If u is NOT a function of x, what is it? A constant? If that were so, you would be asking how to write an equation in x and y, a function of x, in terms of x only, and that cannot be done.
Yes, you are right. I just could not think simple, (may be it can be written as u(x) instead of u, for being more clear, but u is commonly used as a function of x, i should have remembered that),anyway, i reduced the ode to Bessel's eqn. Thanks for your help again.
hey pips can you help me solve this one:
xy'' - y' + y = 0...in terms of bessel functions
Try this substitution:
[tex]X=2\sqrt{x}[/tex]
[tex]Y=\frac{y}{x}[/tex]
Hey could you help me solve
x^2*y''+2x*y'+x^2*y=0
