Differential Equation: Separation of Variables
The discussion revolves around solving a differential equation of the form dL/dp = L/2, with an initial condition L(0) = 100. The original poster expresses confusion about arriving at the solution provided in their textbook.
  • Participants discuss the separation of variables method and question the original poster's approach to applying the initial condition. There are suggestions to correct the integration steps and to reconsider the form of the differential equation used.
Some participants have pointed out potential mistakes in the original poster's solution attempt, specifically regarding the manipulation of the differential equation and the application of the initial condition. There is an ongoing exploration of different methods to approach the problem, including separation of variables and linear equation theory.
Participants note that the original poster may have misunderstood the setup of the equation and the integration process, leading to confusion about the initial condition application. There is an emphasis on deriving results correctly from the differential equation.
brikayyy
dL/dp = L/2, L(0) = 100. Find the solution to the differential equation, subject to the given initial condition. My textbook says the answer is L = 100ep/2, but I don't know how to get that answer (or e for that matter).
dL/dp = L/2
L dL/dp = 1/2
∫LdL = ∫(1/2)dp
L2/2 = x/2 + C
L2 = x + 2C
(0)2 = 100 + 2C
Thanks for any help ahead of time!
I found two mistakes in your procedure. In the second step of your solution, the L on the left side should divide dL.
Then, the way to apply the initial condition is to make x=0, L=100, and solve for C. You did x=100 and L=0. D:
Oh, man. D: Thanks for pointing that out!
Now that I think about it, it looks like I'm supposed to use dy/dx = ky instead of what I did in my attempt?
You don't need a formula, you can derive the result by separation of variables. But as ymlc pointed out you are making a mistake. You should have dL/L=(1/2)dp after separating. NOT LdL=(1/2)dp. Work from there.
That equation can be solved either by separation of variables or using linear equation theory and multiplying by an integrating factor. Or, for that matter, as a constant coefficient DE if you have had that method.
