Differential equation w/o an x variable
15 replies · 3K views · last reply
robbondo
[tex]y\prime = ay - by^{2}[/tex]
Is this a linear DOE? If so when I use the integrating factor method, would the int. factor be
[tex]e^{-a\int?}[/tex] ? would it by dy or dx? I think I'm missing the big picture with this process.
Have you tried factoring out the y, dividing over, and partial fractions?
Hmm... Well when I factor out y and divide I get
[tex]\frac{y\prime}{y} = a - by[/tex]?
can I integrate with that y on the other side still?
No
Try factoring more like this:
[tex] ay-by^{2}=y(a-by)[/tex]
Divide by the whole thing on the right and try partial fractions
I don't see how that will work... I'm confused.
Sooo...
[tex] \int\frac{dy}{y(a-yb)}=\int dx[/tex]
Do you understand how to do the left side? Use partial fractions
OK so I did the partial fractions took the integral and then did some moving around of logs to get [tex]y = \frac{a^{2}}{e^{x} + ab}[/tex] Does that look close to anything you might have gotten. I'm not super confident in how I manipulated the logs.
Maybe, you should get an e somewhere in your answer. If I have time later maybe I'll check it for you.
Nope, doesn't look quite right. And you're missing a constant of integration. Can you show more work?
If you even show your partial fractions that you created, it'd be very helpful
So, when I did the separation of variables I got
[tex]\frac{1}{a} \int{\frac{dy}{y}} + \frac{b}{a} \int{\frac{dy}{a-by}} = \int{dx}[/tex]
then when I took the integrals I get
[tex]\ln{y^{-a}} - \ln{(a-by)^{-a}} = x + c[/tex]
so then I messed around and combined the logs into a fraction, and since they were both to the -a I just switched to put the a-by on top and the a y on the bottom, then i took the whole thing to the power of e to get rid of the ln, and then brought the a out to the front.
[tex]a(\frac{a-by}{y}) = e^{x+c}[/tex] then multiplying a into the fraction and solvinf for y I get
[tex]\frac{a^{2}}{e^{x+c} + ab } = y[/tex]
where'd I screw up? :)
Put the a over on the dx side first. And I don't know how it turned into a '-a'. That 'a' should wind up inside the exponential.
I didn't mean separation of variable, I mean partial fractions... sorry
yeah multiplying that a makes it much simpler...
So then I get
[tex]\int{\frac{dy}{y}} + b\int{\frac{dy}{a-by}} = a \int{dx}[/tex]
then I get
[tex]\ln\{\frac{y}{a-by}} = ax + c[/tex]
then raised to the e
[tex]\frac{y}{a-by} = ce^{ax}[/tex]
so then when i solve for y I get [tex]y = \frac{ace^{ax}}{1+bce^{ac}}[/tex]
