Differential Equations not solvable
5 replies · 2K views
bubblewrap
In the first image it shows the ##\alpha^2-w_0^2<0## situation whereas in the second image the situation is when ##\alpha^2-w_0^2=0##.The problem is the book says to use ##T_0=2\pi/w_0## to determine diabetes but you can't do that when ##\alpha^2-w_0^2=0## because it can't be put into a cosine function. What do I do in this situation?
I don't see the second image. Fig 2. has ##\alpha^2-\omega_0^2>0##, not = 0. But the picture doesn't look credible at all. It looks more like underdamped to me.
Your book makes a mess of things with "three types, depending on ##\alpha^2-\omega_0^2>0##, < 0 or zero. These three types correspond to overdamped, critically damped and underdamped cases".
Confusing, to put it mildly:
##\alpha^2-\omega_0^2>0 \qquad \Rightarrow ## overdamped
##\alpha^2-\omega_0^2=0 \qquad \Rightarrow ## critically damped
##\alpha^2-\omega_0^2<0 \qquad \Rightarrow ## underdamped​
Check out a better text, e.g. here
And yes, in the case of critical damping there are no oscillations.
By the way, I don't hear the book saying to use ##T_0##. Did you quote correctly ?
I meant Exercise 2 not the Figure 2, sorry for not pointing it out. And ##T_0## is on a different page, uploaded below.
It looks as if they want you to make quite some assumptions for this exercise: reliable measurements to begin with. G0 = 70. And no additional glucose dosing in between, ...
If glucose concentration goes from 95 via 65 to 75 that means something significant for T0 . Agree ?
( Could such measurements be consistent with critical damping ? )
The measurements can be consistent if the function is of the form ##(a-bt)e^{ct}## where ##a##,##b## and ##c## are positive. I don't know the actual meaning of ##T_0## but from the hint I guess it has got something to do with the level going down to normal again.
bubblewrap said:
The measurements can be consistent if the function is of the form ##(a−bt)e^{ct}## where a,b and c are positive
(I suppose you mean c is negative) Oh ? How do you come to that conclusion ?
From http://www.uprh.edu/rbaretti/Glucose1.htm
