Differential Equations: Separable Equations
The discussion revolves around solving a separable differential equation of the form dy/dx = x/(y^2√(1+x)). Participants are exploring the integration of both sides after separating the variables.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the separation of variables and integration attempts, with some noting a potential error in the original setup. There are questions about the integration of the right-hand side and the use of substitution methods.
Several participants have provided guidance on the integration process and substitution techniques. There is an ongoing exploration of how to handle the integration of the right-hand side, with various interpretations being considered.
Some participants express confusion about the substitution method and how to derive the necessary differential elements. There is a recognition of missing steps in the integration process, particularly regarding the manipulation of variables.
KallKoll
Solve the equation
I separated them:
y^2 dy = dx/√(1+x)
I then integrated the dy side, I got (1/3)y^3 + C. I am stuck at integrating the dx side. Thanks in advance!
KallKoll said:
Solve the equation
I separated them:
y^2 dy = dx/√(1+x)
Shouldn't that be ##\int y^2dy = \int \frac{x}{\sqrt{1+x}}dx##?
For the RHS, try ##u^2 = 1 + x##.
KallKoll said:
Solve the equation
I separated them:
y^2 dy = dx/√(1+x)
You dropped an x from the numerator on the right side.
Yes that should be, thank you. How does the u^2 work?
Did you try it? Post what you have. Latex formatted please.
Well, I set [itex]\sqrt{1+x}[/itex] = u. Then I set u2 = 1 + x. But I don't understand how to get du from that or how that helps with getting rid of the x on top.
[tex] \frac{x}{\sqrt{1 +x}} = \frac{u^2 - 1}{u} = u - \frac1u \\[/tex]
From [itex]u^2= 1+ x[/itex], [itex]x= u^2- 1[/itex] and [itex]2u du= dx[/itex] so
[tex]\int \frac{xdx}{\sqrt{1+ x}}= \int \frac{(u^2- 1)(2udu)}{u}= 2\int (u^2- 1) du[/tex]
Thank you so much!
  • · Replies 25 ·
