Graduate How Does the Chain Rule Define the Differential of a Function on a Manifold?
The differential of a function f at a point p in a submanifold M is defined using a smooth curve α that passes through p, with its derivative at that point denoted as v. The discussion emphasizes the application of the chain rule to express the derivative as (f ∘ α)'(0) = df(α(0)) * α'(0) = df(p)v. It highlights the importance of defining df in a way that maintains the chain rule's validity. Additionally, the conversation references the construction of a function g that relates the mappings between manifolds and Euclidean spaces, allowing for differentiation using the chain rule. This approach clarifies how to interpret the differential in the context of manifold theory.
Maxi1995
We define the differential of a function f in
$$p \in M$$,
where M is a submanifold as follows
In this case we have a smooth curve ans and interval I $$\alpha: I \rightarrow M;\\ \alpha(0)= p \wedge \alpha'(0)=v$$.
How can I get that derivative at the end by using the definitions of the derivative of a function in several variables?
Thank you for your answer. So I got it right, that it is possible to interpret the differential via the chain rule as $$(f \circ\alpha)'(0)=df(\alpha(0))*\alpha'(0)=df(p)v?$$
You define ##df(\ldots)## in a way that the chain rule holds, so the other way around. I.e. first you get a function ##g## defined by the commutativity of
\begin{equation*}
\begin{aligned}
M &\;\quad \stackrel{f}{\longrightarrow} &N\\
\downarrow{\varphi}&&\downarrow{\psi}\\
\mathbb{R}^m &\;\quad \stackrel{g}{\longrightarrow} &\mathbb{R}^n
\end{aligned}
\end{equation*}
that is ##g=\psi \circ f\circ \varphi^{-1}## which you now can differentiate (with the chain rule) to define ##df##. You neglected ##\psi## in your equation.
  • · Replies 36 ·
  • · Replies 73 ·
