Differentials and Implicit Differentiation
The discussion centers on the challenges of understanding implicit differentiation as presented in Feynman's Lectures, particularly in the context of proving gravitational potential inside a hollow sphere. The original poster struggles with the concept, especially when Feynman appears to differentiate with respect to different variables on each side of an equation. Clarifications are provided regarding the nature of differentials, emphasizing that they represent infinitesimal changes and can involve multiple variables, including constants. The conversation also addresses the potential omission of a negative sign in Feynman's work, suggesting it may have been an oversight. Overall, the thread highlights the complexities of implicit differentiation and the nuances of applying it in physics.
Roo2
I'm reviewing physics using Feynman's Lectures, and I'm finding that he frequently uses implicit differentiation in his lessons. This is unfortunate for me because I never got the hang of it beyond the simplest cases. I'm currently going through the proof that the gravitational potential inside a hollow sphere is zero. I almost got through it, but at one point (outlined below in red) he uses an implicit derivative and loses me. Could someone please explain how this works?
I'm used to two-variable implicit differentiation, where one variable (y) is dependent upon the independent variable (x). Thus, if you have an implicitly defined function such as
x^2 + y(x)^2 = 25
it can be solved by deriving with respect to this independent variable:
d(x^2)/dx + d(y^2)/dx = d(25)/dx
2x + 2y*dy/dx = 0
dy/dx = -x / y
Is this an incorrect way of thinking about it? I can't relate it to what Feynman is doing in the image above. First, he doesn't seem to be deriving with respect to anything; he's just taking the differential. What are the rules for this operation? Second, it's as if he's deriving with respect to r on the left side (r^2 ---> 2r dr) and with respect to x on the right side (a^2 + R^2 -2Rx ---> -2R dx). How is it "mathematically legal" to arbitrarily pick different variables to differentiate with respect to on the two sides of the equation?
On a hopefully more simple note, in the blue box within the red box, where did he hide the negative sign which appears in front of 2R dx?
Thanks to anyone who can help clear this up. I never really got implicit differentiation down in high school calculus and somehow I got through multivariate and diff eq without really understanding the concept.
d/dx (F(y(x)) = dF/dy * dy/dx
Stated above
It is just the differential
d(r^2)=2r dr
d(a^2+R^2-2Rx)=-2R dx
\text{d}F=\sum_{k=1}^n \dfrac{\partial F}{\partial x_k} \text{d}x_k
for however many variable there are, in this case only one variable on each side.
as an aside, whenever you differentiate over functions the d(whatever) is multiplied by the chain rule, quick example:
y=x^2
dy=2xdx
dy/dx=2x
a natural extension for multi variables.
d(r^2)=2r dr
Thank you! I didn't notice that R is also held constant by the physical situation. So if R was also a variable in this problem, the differential would be 2r dr = 2R dR - 2xdR - 2Rdx?
y=x^2
dy=2xdx
dy/dx=2x
That makes a lot of sense. Thanks for that explanation. So the differential is the total infinitesimal distance moved across all available degrees of freedom? Is there notation that specifies the differential across a subset of available dimensions? For example, for a 3D function F(x,y), how would you denote the differential only along x?
Finally, in the blue box from my image above, did Feynman make a mistake in dropping the negative sign, or am I missing something?
Thanks again for all the help!
yes, but only if we assume a^2 is a constant (is this true? it seems x^2+y^2=a^2, and if this is the case we need to differentiate over that a^2. without more knowledge of this problem i can't say.
not necessarily over all degrees of freedom. consider partial derivatives. lurflurf outlined general notation for the F(x,y). specifically, let n=2 recognizing x_2 is equivalent to y (this is natural at higher dimensions). it seems with your hypothetical R you understand, so not sure where the confusion is.
it seems so, though sometimes physicists are permitted to make assumptions mathematicians are not. nonetheless, what about the x that's in the a (assuming x^2+y^2=a^2)?
Yes that is right.
I prefer to thing of it as the closest linear function. Often it is helpful to approximate differences of a function by small but not infinitesimal differentials. Also dealing with infinitesimals carelessly leads to logical errors. There is such a thing as a partial differential
d_{x_k}F=\dfrac{\partial F}{\partial x_k} \text{d}x_k
so
\text{d}F=\sum_{k=1}^n d_{x_k}F=\sum_{k=1}^n \dfrac{\partial F}{\partial x_k} \text{d}x_k
The total differential is invariant, meaning it is the same in any coordinate system. Partial differentials do not share this advantage, limiting their usefulness.
Yes a minus disappeared.
Some of these confusions become clear when we realize each (partial or total) derivative (or differential) we see depends upon how the variables are related. It is convenient to omit such information when obvious. It is a minor abuse to denote a function f(x) as y because F(x,y)=F(x,f(x)) for example.
I think there was no reason to omit the minus sign..
  • · Replies 25 ·
  • · Replies 24 ·
