How do you differentiate (x^2)^(ln[x])?
  • Thread starter Thread starter indie452
    Differentiate
The differentiation of the function (x^2)^(ln x) involves applying the chain rule and logarithmic properties. The expression can be rewritten as e^(2(ln x)^2) by utilizing the identity ln(x^2) = 2ln x. The derivative is then calculated as (4ln x)/x * e^(2(ln x)^2), which simplifies to (4ln x)/x * (x^2)^(ln x). This method effectively demonstrates the use of logarithmic differentiation for complex exponentials.
  • Understanding of logarithmic differentiation
  • Familiarity with the chain rule in calculus
  • Knowledge of exponential functions and their properties
  • Basic proficiency in LaTeX for mathematical notation
  • Study the application of the chain rule in differentiation
  • Learn more about logarithmic differentiation techniques
  • Explore the properties of exponential functions in calculus
  • Practice using LaTeX for writing mathematical expressions
Students studying calculus, mathematics educators, and anyone looking to enhance their skills in differentiation techniques, particularly involving logarithmic and exponential functions.
indie452
differentiate (x2)lnx
im having a blonde moment...how do you start?
Write x as e^{\ln x}.
ok so you mean write
eln(x2)^ln(x)
this gives me eln(x)*ln(x2)
Yes that's correct. You can write the part in the exponent slightly easier by using \ln x^2=2\ln x. Now you just have to use the chain rule.
Cyosis said:
can write the part in the exponent slightly easier by using \ln x^2=2\lnx.
how can you say this?
I 'said' that, because in the latex code I wrote 2\lnx, \lnx is not a command in latex so it doesn't recognize it. I added the space now so it becomes 2\ln x, which should display the correct result.
Edit: I see you edited post 3, but what you did there is not correct. (x^2)^{\ln x}=(x)^{2 \ln x}=(e^{\ln x})^{\ln x^2}=e^{\ln x \ln x^2} \neq e^{(\ln x^2)^{\ln x}}.
He didn't say it. (Unless he editted his post immediately after your response.) He said ln(x2)= 2ln(x).
On edit: And while I was typing this, he explained!
Using that
(x^2)^{ln(x)}= e^{(ln(x))(2ln(x))}= e^{2(ln(x))^2}[/itex]
ok i got
e(2(lnx)2)
differentiating gives
(4lnx)/x * e(2(lnx)2)
Yes, that's right.
Another way to differentiate y= (x^2)^{ln x} is to take the logarithm of both sides: ln(y)= ln((x^2)^{ln(x)}= ln(x)(ln(x)^2)= 2 (ln(x))^2
Now, differentiating both sides with respect to x,
\frac{1}{y}y'= 4 ln(x)\frac{1}{x}
y'= \frac{4 ln(x)}{x} y= \frac{4 ln(x)}{x}(x^2)^{ln(x)}
(If you were given the problem as (x^2)^{ln x} it is probably better to write the answer using that rather than e^{2(ln x)^2}.)
