Differentiating Complex Exponentials
4 replies · 3K views · last reply
Matty R
Hello :smile:
I'm currently using past papers to revise for January exams, and I've found a bit of a problem with something I thought I was okay with.
The position at time t of a particle undergoing damped oscillations is given by:
[tex]x = 2e^{-t}\sin(3t)[/tex].
Express this in terms of a single complex exponential.
Hence evaluate the particle's velocity, [tex]v = \frac{dy}{dx}[/tex]
[tex]e^{i \theta} = cos(\theta) + isin(\theta)[/tex]
Chain Rule: [tex]\frac{dy}{dx} = \frac{dy}{du} \cdot \frac{du}{dx}[/tex]
[tex]x = 2e^{-t}sin(3t)[/tex]
[tex]sin(3t) = \text{Im} \left[e^{i3t} \right][/tex]
[tex]x = \text{Im} \left[2e^{-t}\cdot e^{i3t} \right][/tex]
[tex]= 2 \text{Im} \left[e^{-t} \cdot e^{i3t} \right][/tex]
[tex]= 2 \text{Im} \left[e^{-t + i3t} \right][/tex]
[tex]= 2 \text{Im} \left[ e^{(-1 + 3i)t} \right][/tex]
[tex]v = \frac{dx}{dt}[/tex]
[tex]= 2 \text{Im} \left[(-1 + 3i) e^{-t} (cos(3t) + isin(3t)) \right][/tex]
[tex]= 2e^{-t} (-cos(3t) - 3sin(3t))[/tex]
Thats the answer I get by following the only example I have of this from my lecture notes. However, that example was concerned with the real part of the complex exponential.
The baseline solutions to the paper give the following answer:
[tex]v = 2e^{-t}(3cos(3t) - sin(3t))[/tex]
Does anyone know what I've done wrong, or missed?
Thanks.
Hello Matty R! :smile:
You've taken the real part …
just take the other bits instead! :wink:​
(and chuck away the i)
Hiya tim. Nice to see you again. :smile:
That makes perfect sense. I've managed to get the same answer as the solutions now, and I was wondering if you'd be so kind as to confirm what I did.
For the real part:
[tex]2e^{-t} \left[(-1 \times cos(3t)) + (3i \times isin(3t) \right][/tex]
For the imaginary part:
[tex]2e^{-t} \left[(3i \times cos(3t)) + (-1 \times isin(3t) \right][/tex]
Then discard the "[tex]i[/tex]"s
