Differentiating Inverse Functions
8 replies · 16K views
BuBbLeS01
Please HELP...Differentiating Inverse Functions
f(x) = x^3 + 2x - 1 when a=2
2. The attempt at a solution
I thought you did...
1/(f '(f-1(x)))
but I am not sure how to solve for x?
0=x^3 + 2x - 1
1=x^3 + 2x -1
I tried factoring but that did not work either.
if it is f-1(a) when a = 2...
set the first equation equal to 2, which will happen when x = 1.
So, f-1(2) = 1.
Now if you want f-1'(x), you have:
= 1 / f'(f-1(x))
so 1/ f'(1)
find the derivative of f(X):
3x^2 + 2
so,
answer = 1/(3(1) +2) = 1/5.
How do you know it is 1? Because that's the only number without an X term?
frasifrasi was not supposed to give away the answer, if that's the answer. That's not how this forum's supposed to work.
f -1(2) is the answer to question, "at what value of x does x^3 + 2x -1 = 2"?
frasifrasi assumed f(x) = a, which may or may not be justified. Your statement of the problem does not indicate what a is. If that assumption is right, then f -1(f(x)) = f -1(a), and by the definition of an inverse function, f -1(f(x)) = x. So x = f -1(a). You can verify that when x = 1, f(1) = 2. Therefore 1 = f -1(2).
Yea I thought it was weird that he just gave the answer. But I am trying to figure out how you figured out that x^3 + 2x - 1 = 2 when x= 1?
He solved the equation of course! Cubics can be difficult to solve so I suspect he did what I would: try some easy numbers for x and hope one works. In "real life" that is seldom true but in "made up" exercises it often is.
