Differentiation Problem: Find the Derivative of y = 1/ COS(t^2)
  • Thread starter Thread starter andrey21
    Differentiation
The problem involves finding the derivative of the function y = 1/ COS(t^2), which falls under the subject area of calculus, specifically differentiation techniques.
  • The original poster attempts to use the chain rule and expresses uncertainty about their technique. Some participants suggest alternative methods, such as applying the chain rule twice or using the quotient rule. Others point out that the function can be expressed as sec(t^2), which may simplify the differentiation process.
The discussion is ongoing, with participants exploring different approaches to the problem. There is no explicit consensus on the best method, but various suggestions and clarifications are being offered.
Some participants question the original poster's application of the chain rule and suggest that there may be confusion regarding the differentiation techniques. The original poster's understanding of the function's representation is also under discussion.
andrey21
Find the derivative of the following:
y = 1/ COS(t^2)
Here is my attempt
Using (Cos(t^2))^-1
SOlve using the chain rule:
u = t^2
du = 2t
dy/dt = -1.(-sin(u))^(-2) .(2t)
= -2t(-sin(u))^(-2)
= -2t/(Sin(t^2))^2
Is this correct or have I totally used the wrong techiniques?
This isn't correct. Try applying the chain rule twice, starting with u=cos(t^2).
You can do it whatever way you want, but I would use the quotient rule. It seems less confusing to me.
Your function is the same as sec(t^2). If you know the rule for the derivative of the secant function, you can use that (plus the chain rule).
9K
