How Long Until a Cursed Civilization's Population Reaches Zero?
The discussion centers on a mathematical model describing the decline of a cursed civilization's population, starting at 676 individuals, with a weekly change defined by ΔP = -√P. The user seeks a calculus-based solution to determine how many weeks it will take for the population to reach zero, expressing frustration over the complexity of the problem. Responses indicate that while a discrete-time difference model is appropriate, using calculus can provide an approximate solution by solving the differential equation dP/dt = -√P. However, the challenge lies in the fact that population values must remain integers, complicating the application of both methods. Ultimately, the conversation highlights the limitations of mathematical models in accurately representing real-world scenarios.
Math Henry
[/B]
Summarizing: two civilizations hate each other, one of the civilizations throws a curse at the second. The second civilization succumbs to chaos and has a change in Population each week of ΔP= -√P. That is:
Pn = Pn-1-√Pn-1
[/B]
Considering that the civilization starts with a population of 676 people, how many week until it reaches zero?
[/B]
I know it's solution uses differentiation and i know it's probably easy, but i can't seem to get a grasp at it, and it really frustrates me. I've done it manually and is ≅50 weeks, but that didn't satisfied me and i need that answer nice and tidy using calculus. Please help me out. Thanks in advance
Math Henry said:
[/B]
Pn = Pn-1-√Pn-1
[/B]
[/B]
Your model is a discrete-time difference model, so calculus is not really appropriate for it. Doing it manually is absolutely the correct way to go.
If you really do want to use calculus to get an approximate (not exact) answer, you can solve the differential equation
$$ \frac{dP}{dt} = -\sqrt{P}, \; P(0) = 676$$
and determine where ##P(t) = 0.##
The real problem is that neither the discrete-time difference method of the continuous-time calculus method captures reality---the fact that at any time ##P(n)## or ##P(t)## must be an integer. Thus, the equation ##P(n+1) = P(n) - \sqrt{P(n)}## cannot hold exactly because it often produces a non-integer result for ##P(n+1)##. It is not at all clear how to fix this up.
Likes Math Henry
Thank you Ray for the quick reply, at least now i know that the answer is not that obvious.
So, if I ignore the fact that I am using a model of population which can only hold meaning for integer populations, that is, any result P ∈ ℕ, and instead treat it like an ordinary system which accept results P ∈ ℝ , i get, by integrating both sides:
$$ P(t) = 676 - \sqrt{P}*t $$
Is that the furthest i can go in this problem with calculus? P.S.: I know that i can solve that kind of problem easily with a simple Python or FORTRAN program for bigger populations, but the book it never mentioned the need for it.
Is that the furthest i can go in this problem with calculus?P.S.: I know that i can solve that kind of problem easily with a simple Python or FORTRAN program for bigger populations, but the book it never mentioned the need for it.
No, you do NOT get ##P(t) = 676 - \sqrt{P(t)} t##; that is not how you solve a differential equation. Anyway, your notaton ##\sqrt{P} * t## is meaningless, since there is only one ##P## here---and it takes ##t## as an argument. When we write a differential equation as ##dP/dt =-\sqrt{P}## that is really shorthand notation for ##dP(t)/dt = -\sqrt{P(t)}##.
Google "differential equation" for more information, or look in your textbook if you have one (and if it covers that topic). Even better: Google "separable differential equation".
Likes Math Henry
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
