Differentiation using product rule?
The discussion focuses on differentiating the function p(x) = ((x+5)^2)*((x+3)^7) using the product rule. The initial differentiation attempt yielded a correct result but was deemed incorrect due to lack of simplification. Participants suggested factoring out common elements to simplify the expression further. The final simplified form of the derivative is presented as ((x+3)^6)*((9x^2)+(86x)+205) or alternatively as (x+3)^6*(x+5)*(9x+1). The conversation emphasizes the importance of proper algebraic manipulation after differentiation.
steve snash
Differentiate the following function with respect to x,
p(x) = (( x+5 )^2)*(( x+3 )^7)
well the product rule is,
p(x)=(f)*(g)
p'(x)= (f')*(g)+(g')*(f)
and general differentiation is,
p'(x)=n(f)^(n-1)*n(g)^(n-1)
well i used the product rule and got
(2(x+5))*((x+3)^7)+(7(x+3)^6)*((x+5)^2)
but this is said to be wrong how do i simplify it more or what have i done wrong?
What you did is right. They probably just want you to pull out the common factors to simplify it more.
so i could go,
(2*x+10)*(x+3)^7+(7x+21)*(x+5)^2
then
(3x+13)^7+(8x+26)^2
steve snash said:
so i could go,
then
(3x+13)^7+(8x+26)^2
Your algebra is looking pretty seriously awful there. Whoa. Just factor out (x+5)*(x+3)^6 and collect the rest. Try and use only real algebra this time, and not just random symbol rearrangment, ok?
so it works out to be,
cheers for the help
cheers for the help
That's one version. You could also write it as (x+3)^6*(x+5)*(9x+1). Whatever works, like I said your initial differentiation was correct as well.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
