Difficult rational expressions thinking question
The discussion revolves around solving the equation (3x-18)/((2x+1)(7x-3)) = B/(2x+1) + C/(7x-3) to find the values of B and C. Participants clarify that by equating coefficients from both sides of the equation, one can derive a system of equations: 3 = 2B + 7C and -18 = B - 3C. A user successfully solves these equations, finding B = -9 and C = 3, but later realizes that the roles of B and C were initially reversed in their setup. The conversation emphasizes the importance of correctly identifying coefficients and constants when dealing with polynomial identities. Overall, the thread provides valuable insights into solving rational expressions and the significance of careful algebraic manipulation.
AvocadosNumber
Find the Values of B and C given this:
<br /> \frac{(3x-18)}{(2x+1)(7x-3)}= \frac{B}{2x+1} + \frac{C}{7x-3}<br />
The equation given:<br /> \frac{(3x-18)}{(2x+1)(7x-3)}= \frac{B}{2x+1} + \frac{C}{7x-3}<br />
My attempt:
<br /> \frac{(3x-18)}{(2x+1)(7x-3)}= \frac{B(2x+1)+C(7x-3)}{(2x+1)(7x-3)}<br />
<br /> 3x-18=B(2x+1)+C(7x-3)<br />
At this point I'm stuck and I think something I did was wrong.
I'd appreciate any assistance that could be provided!
My attempt:
If your last equation
<br /> 3x-18=B(2x+1)+C(7x-3)<br />​
is true for all values of x, then the initial rational equation
\displaystyle \frac{(3x-18)}{(2x+1)(7x-3)}= \frac{B}{2x+1} + \frac{C}{7x-3}<br />​
will be true for all x except 3/7 and -1/2 .
There are at least a couple of ways to solve the identity
for B & C.
One is to pick a couple of values for x, which will give you two equations in the two unknowns, B & C. One such value is x = -1/2 .
Another method is to equate the coefficient of x on the left with the coefficient of x on the right; also equate the constant term on the left with the constant term on the right.
Hi, Thank You so much for your response. I was just wondering if you could clarify what you meant by this:
I apologize my math vocab is weak.
He means that you can expand 3x−18=B(2x+1)+C(7x−3) as 3x-18=2Bx+B+7Cx-3C. Cleaning this up a bit, we get 3x-18=(2B+7C)x+(B-3C). Two polynomials are equal only if their corresponding coefficients are equal, we get 3x=2B+7C and -18=B-3C. This is a system of equations which you should be able to sove.
HS-Scientist said:
we get 3x=2B+7C and -18=B-3C. This is a system of equations which you should be able to solve.
But don't I have 3 variables still?
I am sorry, there should be no x there. If 3x=(2B+7C)x, then 3=2B+7C. I apologize for not using latex, I am just beginning to learn as I am new to these forums.
If you expand the right side & collect terms, you get
\displaystyle (2B+7C)x+(B-3C)\,,\ right?​
So, the coefficient of x on the left, which is 3 must equal the coefficient of x on the right, which is 2B+7C . Similarly, the constant term on the left must equal the constant term on the right.
These must be equal because, the equation, \displaystyle \ 3x-18=B(2x+1)+C(7x-3)\ is true for all possible values of x, thus this equation is an identity.
Hi! Thank you both for responding.
I'm with you guys so far until here:
3x−18=(2B+7C)x+(B−3C){}
I don't quite understand why 3x must only equal (2B+7C)x.
After I try and solve this is what I get. Is everything I did okay because I don't know and method of verifying if this is right (not from a textbook)?
-18=B-3C
B=-18+3C
3x=(2B+7C)x
3=2B+7C
sub in B=-18+3C
3=2(-18+3C)+7C
3=-36+6C+7C
39=13C
C=3
B=-18+3C
B=-18+3(3)
B=-18+9
B=-9
∴B=-9 and C=3
-18=B-3C
B=-18+3C
3x=(2B+7C)x
3=2B+7C
sub in B=-18+3C
3=2(-18+3C)+7C
3=-36+6C+7C
39=13C
C=3
B=-18+3C
B=-18+3(3)
B=-18+9
B=-9
∴B=-9 and C=3
Yes, you solved it right. But \frac{(3x-18)}{(2x+1)(7x-3)}= \frac{B}{2x+1} + \frac{C}{7x-3} actually leads to the equation 3x-18=B(7x-3)+C(2x+1) Which is not what you originally posted. The B and C are backwards.
As to your first question Ax+B=Cx+D for all values of x means A=C and B=D. Can you show that?
Ah, I plugged in the values of B and C and the expressions on both sides were equal. And that quote clarified quite a lot.
Thank you so much to all of you for the help!
Dick said:
.., actually leads to the equation 3x-18=B(7x-3)+C(2x+1) Which is not what you originally posted. The B and C are backwards.
Sorry. I didn't check the details.
  • · Replies 25 ·
