Diffracted photon/partice momentum
The discussion revolves around the behavior of photons in diffraction experiments, particularly focusing on momentum changes, energy, and the implications of quantum mechanics in interpreting these phenomena. Participants explore concepts related to single and double slit experiments, the nature of photons, and the measurement of their properties.
  • Some participants question what cancels the momentum change of a photon when it forms a diffraction pattern and what happens to its energy or frequency.
  • Others argue that photons exist in both slits simultaneously, challenging classical interpretations of their behavior.
  • It is suggested that without measuring a photon's momentum, there is no defined momentum change, as photons do not follow classical trajectories.
  • Some participants assert that the total momentum of the photon and the slit-apparatus is conserved, provided no external forces act on the apparatus.
  • There is a discussion about the implications of measuring photons, where measuring their momentum would destroy the interference pattern.
  • Some participants emphasize that photons do not have definite trajectories, making discussions of direction change problematic.
  • The role of boundary conditions in experiments is raised, noting that different setups can affect the electromagnetic field and the behavior of photons.
  • There is a debate about measuring the time of flight of photons and whether it is possible to measure a single photon twice without destroying it.
  • Some participants argue that photons can travel in non-straight-line trajectories and do not have to adhere to classical speed limits.
Participants express multiple competing views on the nature of photons, their momentum, and the implications of measurement in diffraction experiments. The discussion remains unresolved, with differing interpretations of quantum behavior and measurement effects.
Participants note the limitations of classical analogies when discussing quantum phenomena, and the discussion highlights the complexities of measuring quantum objects like photons, which do not conform to classical expectations.
negative
when a single photon is supposed to form a diffraction pattern, they hit the detector by different angles at the slit.
so then what cancels this photon's momentum change? what happens to the photon's energy/frequency?what measurements has been done to confirm the answer?
I think your question is based on a fallacy. Photons, single or otherwise, pass through both slits. By "pass" I mean the EM (quantum) field exists in both apertures in the case described.
What momentum change? The photons aren't classical billiard balls following classical trajectories. They are quantum objects. If you don't measure their momentum, there is no "momentum change". (And if you do measure the momentum, you know which slit each photon goes through, so the interference pattern disappears.)
The total momentum of photon + slit-apparatus is conserved.
(provided no external forces (interactions) act on the slit-apparatus, in which case you either take those forces into account, or enlarge the definition of "slit-apparatus" to include the "source" of those forces)
This is just a macroscopic version of a scattering experiment with a photon and some other particle, e.g. Compton scattering, in which the target electron recoils in such a way as to conserve energy and momentum.
a double slit and single slit experiments are different. still this question applies to both.
in the case of double slit, and single slit experiments, photons, and electrons have momentum, in the direction of their movement. direction of movement changes. any change in the direction is supposed to result in a change of momentum.
in a macroscopic point of view, if you hit something with a hammer, even if it doesn't move, it heats up. sudden small forces transfer energy. a photon is supposed to either split or be affected by a force of unknown nature ( gravitational forces for example ) to have it's trajectory bent.
No. You're still thinking of the photons as little billiard balls. They're not. They don't even have definite trajectories in the experiment, so it's meaningless to say that they have a "change of direction". All you can say is that they go through both slits and end up at the detector.
you can, because you can measure the time which takes for them to get to the detector. assuming we add the timer to the experiment...
yes, and it is good to ask how they differ. The EM field is a quantum mechanical system. At energies of a few ev with slits and such, this system becomes well modeled by one with distinct boundary conditions on the fields. The experiment, whether is has one slit or two, differ in these impose boundary conditions on the EM field. The question you raise assumes that one may measure the location and momentum of a quanta of energy exchanged with the detection device. These details need to be fleshed out and can't simply be left hanging. For example, I could use a lens system to collimate light from one side of the aperture and not the other. A photon collected would then have a momentum in the direction of the acceptance cone of the collimator. However, this collimator, just by being there, will eliminate the portion of the aperture effectively removing it from the interaction. The collimator changes the EM field or system being observed.
[Edit] Incidentally, this type of thought experiment was a very famous component in the Bohr-Einstein debates. Hint: Einstein lost.
How? A photon is destroyed upon measurement, so how can you measure a single photon twice to get a time of flight?
you can always measure a single photon twice. at the point of emission and the point of it's destruction.
the emission system that you use, can implement a timer, the detector can implement a timer. you know the speed of light. you put a straight line from the emission source to the slit, then to the spot that it hit the detector.
this trajectory is the shortest that passes from the slit. and it (supposedly) fits the time that it took for the photon to reach the target.
any other trajectory either doesn't pass through the slit or means exceeding the speed of light.
If you have a source that tells you when it emits a particle, yes, you can measure the time. But that does not tell you the momentum. It only tells you the time of flight. You still don't know, because you're not measuring, the trajectory of the particle (and changing the experiment so you measure the trajectory will destroy the interference pattern).
Photons do not have to travel in straight lines. Nor do they have to travel at the speed of light. Once more: photons are not little billiard balls. They are quantum objects. They have nonzero amplitudes to do things that are classically forbidden, like travel in non-straight-line trajectories or travel at speeds other than the speed of light.
The OP is simply repeating incorrect statements without responding to issues raised, and the original OP question has been answered. Thread closed.
  • · Replies 25 ·
  • · Replies 16 ·
  • · Replies 39 ·
  • · Replies 22 ·
  • · Replies 33 ·
