Diffraction Effects and Artifacts in Telescopes like the JWST
125 replies · 13K views · last reply
sophiecentaur said:
But the stars are stationary and will have their own images after a long exposure - not a grey background.
When I said "stationary," before, I meant that in a statistical sense. I mean a stochastic system that has random properties, but such that the statistics governing the randomness are not changing. In other words, things in the process can change randomly, but the statistics do not change.
https://en.wikipedia.org/wiki/Stationary_process
So long as the star's true brightness is statistically stationary, the standard deviation of its brightness (and that of any of its diffraction artifacts) in the integrated image tend to zero as total integration time increases.
Yes, this could present issues for Cepheid variable stars, depending on the star's period and the integration strategy.
Astronomy news on Phys.org
I tried another diffraction test with 6 spikes, but only so-so results. My exposure times were limited by thin clouds and Bortle 6 light pollution. This is a composite of around 120 exposures of Polaris, about 15 seconds per exposure at 6400iso with wire over the lens to create a 6 spike diffraction pattern.
collinsmark said:
see now that "FAPP" is an acronym. That's the first time I've ever heard that word being used as an acronym. I thought you were shouting an expletive to emphasize your point. (To pound home your point, so to speak.)
My apologies it is was not my intention to shout. It is used a lot on this forum, which is where I came across it, so did not spell it out.
Again sorry for the confusion.
Regards Andrew
This is true but hardly relevant in a situation where a single exposure is made. There is a limit to how much you can give it if you want to avoid burn out of the brightest stars.
Then, you are stuck with the 16 bit limit unless you use stacking, which is a non linear process, so all simple bets are off.
This thread has gone in circles so we really don't know what we agree about and what we disagree about but everyone seems reasonably well informed. As far as I can see, we started off with the fact that bright star images seem to have 'longer' spikes than dim ones. Somewhere in the discussion we have explained why and now we're half in and out of theory and practice. Aren't we done? :smile:
Well since the 1st maxima of an airy disc of red light is larger radius than the 1st maxima for blue light of equal intensities, if we’re imaging laser point sources I wonder if the spikes would be longer for a red laser compared to an equal intensity blue laser. With the question posed this way we don’t have to worry about sky background or sensor sensitivity.
When I look at this test photo I did last night, to my eye the tips of the spikes are red, then a bit inward we have green, and further inward still we have blue.
They will have a 'length' roughly proportional to the wavelength (also the spacing of any 'dots'. That is if everything else is controlled.
But images of sharp objects in space are mostly not monochromatic so we're really looking at the colour fringing at either end of the spikes and differences hard to discern.
I may have been contributing to this thread trending in different direcitons because I like this thread and don't wish it to become a source of misinformation. So when there is a false or misleading claim I can't in good conscience just sit by and let that false claim go unchallenged. And it seems there are many in this thread, which is why, I assume, it's taking twists and turns.
Since you bring up the history of the particular circles, I'll try to consolidate them.
It may have started somewhere around the time of:
sophiecentaur said:
Of course the spacing will be the same but a fainter image will not produce such long spikes because lower amplitude dots are not recordable.
This is subtly incorrect. Yes, maybe in that particular image the dots were not recorded. In that image. Sure. But the dots are not the byproduct of the camera or any part of the imaging hardware. The dots are the result of diffraction/interference of the optics including the Bahtinov mask in this case. And those diffraction dots are, in fact, recordable. So to say that the dots are not recordable isn't true. Therefore I objected.
Then immediately there there was some misinformation about the properties of Full Width Half Maximum (FWHM) by another poster that has since been recanted, so I won't repeat them here. All of that got sorted out. But that did take a few posts to get through.
Then there is another:
sophiecentaur said:
Your data near the peak can be considered to be linear but it eventually ends up being non-linear
This is untrue because the spikes themselves are linear all the way down to the quantum level (and the wavefunction of quantum mechanics [QM] is completely linear as far as anybody can tell for certain).
And if you're not talking about the linearity of the spikes themselves, but limitations of the camera sensor, the linearity of the camera sensor can be made linear with arbitrarily high precision by either by increasing the exposure time if saturation is not a concern, or by stacking. (And thus at this point the process of stacking entered into the discussion).
Also in the same post, we had this, separate separate idea that's not correct:
sophiecentaur said:
The bit depth of the cameras appears to be 16, which corresponds to a maximum relative magnitude of about 12, at which point the artefacts will disappear. That implies a star that is exposed at the limit will only display artefacts down to a magnitude of 12, relative to the correctly exposed star.
That claim is false. The 16 bit depth of the sensor is not the limiting factor. In later posts I explained why, complete with examples and some practical mathematics to achieve increased effective bit depth. But this 16 bit sensor seems to repeatedly brought up as an insurmountable limitation, even though in and of itself, it is not. Of course there are real-world, practical limitations regarding the dimmest things are possible for JWST to resolve. But this least significant step of the 16 bit ADC, by itself isn't one of them.
I'll mention that at some point somewhere around there I had a miscommunication with another poster about FAPPs and fapping, but that ended up getting all sorted out, so I won't rehash that the details here.
With this next post I briefly thought we were in agreement about all of this stuff I just discussed above:
sophiecentaur said:
OK, I already accepted that the sensor itself is linear over a wide range and that stacking will allow a substantial increase in effective bit depth by averaging out random noise. I also know that the maths of diffraction goes on and on, as far down as you like.
So for a moment I thought that we had resolved the disagreements.
But I guess not, because soon after we have:
sophiecentaur said:
It's very misleading because, in a real image there is not a point source and also there are a number of other sources in the vicinity of the low level parts of a diffraction spike. this constitutes a 'floor' which can be significantly above the least significant step in the ADC.
Which again repeats the false claim that the least significant step in the ADC is some sort of insurmountable fundamental limit. It's not.
Furthermore, something new is mentioned about requiring a point source and overlapping patterns. Diffraction applies to all sources, not just point sources. Even if the orientation of JWST is such that the image of a dimmer star lies within the diffraction spike of a brighter star, it is still theoretically possible to resolve the brightness of the dimmer star, it just might take more total integration time and knowledge about JWST's diffraction characteristcs (which scientists are aware of). Will the brightness of the dimmer star necessarily be recorded in any given image? No. But it is recordable. I personally don't take serious issue with any of this until it's brought back to the ADC. Yes, overlapping diffraction patterns complicate matters for sure, but let's keep the ADC out of it.
Then this came out the blue:
sophiecentaur said:
So we agree on that. The only way to increase the effective number of bits is by using multiple images and you say there's no stacking.
Boldface mine.
I never said there was no stacking! Of course there's stacking! There's always at least some stacking. In the JWST image that posted which shows the stacking/overlap, I can see regions of at least 6, maybe 7 overlaps (could be more) and the majority are around 4 or more overlaps.
And here again with the 16 bit thing:
sophiecentaur said:
The linearity failure at low levels can destroy recorded spikes and 16 bits is where linearity fails. Some spikes are never there in 16 bit images.
I'm repeating myself. But 16 bits is not where linearity fails. It may be the case for a single subframe, but there's always at least a little stacking which increases the bit depth in the resulting image. And if science dictates, and more details is necessary, JWST could always can be told to increase its total integration time on that particular target in question and stack more subframes.
And regarding the overlap of diffraction patterns (such as diffraction spikes of brighter stars overlapping the central spot of the diffraction pattern of a dimmer star), yes that makes things more complicated, but not insurmountable. And none of it fundamentally limited by the "16 bit" aspect of the sensor.
And then this post broke my heart:
sophiecentaur said:
@collinsmark seems to be insisting that the limited model of his maths is all that needs to be considered but, in the limited situation of a 16 bit sensor and the presence of many other interfering low level sources there is a very real limit to how far the maths will follow reality. This is not a problem but it's what limits what we can see.
Good grief. Where to start. Not only does the tone of that post start off as snide and condescending, it's wrong. It's wrong in two ways:
  1. Of course there's more to it than just the basic tenets, theorems, and implementation of information theory statistics, and mathematics. and I never said there wasn't anything more to it. But just because there is more to it, those simplistic, basic, theoretical ideas are essential considerations for this topic, and cannot be ignored if further understanding is to be achieved.
  2. There we go again with the 16 bit sensor limitation. Implying that this as a fundamental, insurmountable limitation is wrong.
  3. We can follow the maths all the way down to the quantum level with incredible precision. And this is true, even as applied to JWST images. As a matter of fact it's crucial, since in some cases we are talking about individual photons and their paths which are subject to diffraction and self interference patterns (not dissimilar to the double slit experiment). Implying that the maths and physics don't track reality at that level or above is wrong.
And then, since my last post, there a brand new incorrect claim:
Gah! The stacking process is not nonlinear. With the exception of cosmic ray/hot pixel rejection and removal, (which might be considered part of the stacking process), it's linear in the
  • astrophotography sense: being performed well before the "stretch" or "curves" are applied (stacking is done in the process flow immediately after calibration frames are applied to the raw data from the sensor)
  • the mathematical sense: [itex]\mathcal{O}(x + y) = \mathcal{O}(x) + \mathcal{O}(y)[/itex],
  • and any other sense that I can think of.
Cosmic ray/hot pixel identification, rejection and removal fit in nicely as part of the stacking processes. But this isn't a necessary part of stacking. You could still do stacking without it.
Doing just the stacking alone, the mathematical operation is linear. As a matter of fact, it's mathematically equivalent (statistically speaking) to taking a longer exposure with unlimited bit depth (zero risk of causing saturation beyond that of the subframes), at the expense of additional read noise.
And this addition of read noise does not make the process nonlinear. (Any more than the addition operator is nonlinear, which it isn't.) Nor does this read noise present an insurmountable limitation if the read noise is uncorrelated/(statistically) stationary. The overall effect of the read noise can be reduced via the Central Limit Theorem, just like any other source of uncorrelated, (statistically) stationary noise source.
You're right to be concerned about saturation during a single exposure. Saturation is a primary consideration for determining the exposure length of subframes. After that, enough frames are stacked to bring about the necessary detail and signal to noise ratio (SNR) determined by the scientific needs of the object being imaged. If the science requires more effective bit depth or better SNR, more frames are stacked.
The read noise penalty for stacking is small, although it's not negligible, so it's something that is considered and dealt with. But it's in no way an insurmountable obstacle. And to the point of the last claim, there's nothing inherently nonlinear about it.
Summary:
There are real, true, insurmountable limitations to JWST's capabilities, both theoretical and practical. I've never said otherwise. But things like the finite bit depth of the hardware sensor and the residual, thermal glow of background space are not among them.
Things such as the overlap between the diffraction pattern of one source over another: That makes things complicated (but can be dealt with). Scientists analyzing data must take diffraction into account all the time, with every image. But they do that. That's part of the process. But nothing about that is insurmountable.
There are many, many things that make gathering scientific data from JWST or any other telescope complicated. But not all of them are insurmountable. Many obstacles brought up recently in this thread, while they may have their own complications, and require careful considerations, are not truly limitations. JWST, science and math have ways of getting around them.
So what are some of the true limitations? There are many. Here are a few biggies:
  • Time. Time spent gathering data on anyone given target means less time for gathering data for other targets. JWST has a finite lifespan.
  • Aperture. While JWST's primary mirror may be large, it does limit the angular resolution that it can resolve. It also limits its light gathering rate (although this one points back to the previous bullet).
  • Stochastic, yet (statistically) nonstationary, dim sources. If a source is changing in a non-predictable way, and those changes are occurring fast enough given how bright it is, JWST may not be able to reliably detect those changes in detail.
And while there could be more, nowhere on that list is the 16 bit thing. And stacking is not inherently nonlinear.
@collinsmark I'm sorry but your post is far too long - unnecessarily so for anyone to bother to read thoroughly. With respect, is says little more than "I (i.e. you) was right all the time."
You took exception to a comment that diffraction spikes are all different lengths. Can you show me an image full of stars with equal (displayed) spikes all over it? Perhaps the actual wording of the statement implied something to you that was not intended. No one has suggested that diffraction theory is wrong; diffraction assumes linearity.
Your list of bullet points demonstrates that you weren't actually reading what people had written and you are inconsistent. You started off say there isn't stacking and now you say there is stacking. You talk about the central limit theorem but that involves unlimited exposure time, which will, of course, saturate a sensor. You hop from 16 to 32 bit quantisation and you ignore any effect of nearby stars. 16bits (any sampling and quantising aamof) introduces non-linearity.
You state that stacking is inherently linear but a linear sum of many images is a very crude form of stacking. Each pixel of a stacked image can use and process (e.g. median) selected values from all available pixels. I can't see that is linear.
We are stuck with FAPP and the simple maths fails at some stage.
@sophiecentaur, Who's not reading what other people have written? Could you clarify that? Do you even read what you write?!
Sure. Right here. @Devin-M was kind enough to generate one with direct experiment. Those two stars are of different brightness (as acquired directly from the camera). But when adjusting for the intensity, it's quite clear that the diffraction patterns are of the same size.
Edit:
My objection was your statement where you said the spikes were not "detectable" (italics mine). I don't have an objection to saying that they were not detected in a particular image. But they are in fact detectable.
I never said JWST does not use stacking. I kindly request that you do not put words in my mouth. I've never said that in my life. Not on PF, not anywhere.
That said, I'd be tickled to know where you think I said that. Which post and where. Show me a quote, if you would be so kind.
No it doesn't. It essentially says, among other things, that the standard deviation of a set of averaged trials decreases by a factor approaching [itex]\frac{1}{\sqrt{N}}[/itex] compared to the standard deviation of the original set of trials. It says absolutely nothing about saturating sensors.
The input is already quantized. From the very beginning. It starts with individual, quantized photons. From there all merely count them. We sum them. Sometimes we divide the results by a number. Nothing about any of that is nonlinear.
We can put those numbers in a 16 bit register or a 32 bit register. We can store those numbers in a file using 16 bit format or 32 bit floating point format. It doesn't matter.
Saturation is nonlinear, but that doesn't happen when stacking. That is one of the primary motivations to use stacking in the first place: it avoids saturation and nonlinearity. Stacking is about as linear as linear can get.
What do you think stacking is?
Averaging (as in "mean" -- not median) pixels from different subframes is what stacking is. The addition operator is a very linear operator. Division (by the number of elements summed) is a linear operator. What's not linear about that?!
Where does the math fail? Show me, please.
How might you suggest informing astronomers that use JWST, Hubble (HST), and pretty much any telescope around the world, that their stacking algorithms -- algorithms that they've been using for decades -- are all failures? Do you propose invalidating the countless academic papers that relied on astronomical data that invariably was produced, in part, using same general mathematical principles and theorems discussed here?
Two stars in the image have been manipulated to have equal lengths but other stars in the field show none at all! Regards Andrew
The image was manipulated so they have roughly equal brightness (even though they originally were not). The adjustment was done to make it an apples to apples comparison. The equal sizes naturally fell out of that.
Here is the original image before the stars were adjusted for equal brightness. (But without adjusting for brightness, this is an apples to oranges comparison).
[Edit: I forgot to mention the credit: Image is courtesy of a post by @Devin-M ]
This is a perfect straw man argument. "Failures"? I am simply pointing out that the world of digital (discrete) sampling is inherently non-linear and that, for example, stacking using the median value of samples introduces more non-linearity. (Did I suggest that's a bad thing?) If you use any well known amateur astro software (Say Nebulosity) there are several options of stacking algorithms. One of them is based on the median of the pixel values. (I could ask you whether you know what stacking is.)
You would deny that it's a so-called fair test if we are discussing visibility?
If you could only afford a four bit ADC for the sensor, would you still be able to tinker with the two different parts of the image and squeeze out two equal spike lengths? Once you fall below the minimum sig bit, you have lost that information for ever.
The above shows failure - that's just a practical issue that the basic maths doesn't consider. Is the word 'failure' too judgmental for you? I can't think of a better description for what happens in practice.
In this JWST image, the dimmer stars diffraction spikes (circled red) are the same length as the brighter star’s diffraction spikes, because both extend all the way to the edge of the image frame:
With long enough integration time this will visibly & detectably be the case for every single star in the image, demonstrating the spikes are the same length but different brightness.
These spikes are caused by edges and obstructions in the optical train, not the sensor or the star. See below, I used wires in front of the lens to create a 6 spike diffraction pattern.
Devin-M said:
In this image I took of 2 different brightness stars, adjusted to have equal image intensity (in the 1st image), we’re only seeing the first 3 orders of diffraction on both stars. With equal image intensity both have the same shape size and appearance despite having different apparent observable brightness.
This diffraction / interference pattern was created by placing a window screen in front of the lens...
On the other hand, here is a laser passing through a pinhole (a pinhole which is equivalent to a telescope’s aperature), and we’re seeing no less than 27 orders of diffraction…
https://en.m.wikipedia.org/wiki/Airy_disk
Also, due to shot noise, the diffraction pattern doesn't form from the inside out, but rather across the entire image frame, somewhat randomly...
Devin-M said:
No, it is not nonlinear when the input to the system is already discrete, such as discrete photons. We're not sampling some continuous, analog signal here. We're merely counting photons. That can be done linearly.
Using the median values is not a good way of stacking the bulk of the data for typical purposes if you care about the fine detail of the signal. It has its niche applications though. Using the median value as the stacking is a good way of quickly wiping out noise if you don't mind taking out the fine minutiae of the signal along with it. So there are some fringe purposes for using the median (quick noise reduction where the signal detail isn't a big concern), but it's not typical.
That said, In a typical staking algorithm, median values are commonly only used for bad pixel/cosmic ray detection and elimination. Statistical outliers relative to the median (rather than the mean) in a particular subframe are replaced with median values, or simply rejected from the stacking altogether, for that subframe. So the median is important in that way. (But only for cosmic ray/bad pixel rejection -- otherwise the mean is used.)
Using the median as a reference for pixel rejection, followed by using the mean as the end result of the stacking is a very good way of eliminating bad pixels and cosmic rays, while maintaining the statistical minutia in the signal.
And yes, before you ask, this bad pixel/cosmic ray rejection is nonlinear. That's the one aspect of this that's nonlinear. But cosmic rays and bad pixels are not stationary (statistically) anyway, and almost certainly not part of the signal, so it's a good idea to get rid of them, linearity be damned. But only a tiny proportion of pixels are rejected in this way, so it doesn't negatively affect the final image all that much.
And keep in mind, without stacking, you couldn't even do that. There are no statistical outliers between subframes with only a single subframe. You'd be stuck with that bad pixel or cosmic ray. Trying to eliminate cosmic rays and bad pixels with only a single subframe is not nearly as robust.
I would love to discuss stacking algorithms such as the ins and outs of the Drizzle algorithm. (Probably in a different thread, though.) Drizzle is an advanced stacking algorithm that does everything I've described in this thread about stacking, plus quite a bit more. Many modern implementations of Drizzle are flexible, so if you wanted to keep it simple, such as the methods I discussed in this thread, you could. But you can also use its full power so long as the subframes are dithered during acquisition (commanding the telescope to point in a slightly [or even not so slightly] different direction and/or orientation between subframes).
The Drizzle algorithm is a core component in JWST's pipeline (see the section on "Imaging combination"), It's the algorithm that JWST uses for stacking.
I could discuss stacking algorithms all day. It's something I find fascinating and something I am interested in. Understanding Drizzle requires a firm grasp of basic stacking principles first. But unless we're all on the same page there, it would be like discussing Riemannian geometry without a firm grasp of Euclidean geometry. Something tells me you wouldn't be interested in reading my posts anyway though. Suffice it to say Drizzle involves stacking.
Sure, as long as the data is scaled accordingly, equalizing the relative brightness, so that it becomes an apples-to-apples comparison, even visually.
Once again, I have no qualms with saying that spikes were not detected in some particular image. What I object to is the claim that spikes are not detectable.
Would I "still"? I don't understand, why would I even tinker with two different parts of the same image in the first place? I wouldn't do that. I would be concerned with corresponding pixels between different subframes, not different pixels in the same subframe.
All else being equal, if I switched from a 16 bit ADC to 4 bit ADC, the smart thing to do is reduce the subframe exposure time to avoid saturation in the subframes. To compensate, a greater number of subframes would be taken. That includes a some extra subframes to compensate for the extra read noise. The total integration time would be a little longer, but other that it would be a statistically equivalent system.
No, because I've compensated for that by choosing the exposure time per subframe and number of subframes accordingly. Nothing is lost, statistically speaking.
"Fails" is the word that you chose, not me.
And no, there isn't any failure if you divide up the necessary total integration time between the subframe length and number of subframes wisely, which is something that you would need to do anyway. 'Unless you choose them like an idiot, and then there's failure.
Suppose we have 3 different monochrome laser sources of varying intensity but the same wavelength shining through a diffraction grating and we take 3 exposures of consistent exposure length and consistent processing... Since the photons are discrete & arrive randomly, we end up with three diffraction patterns, all the same angular and pixel dimension size, but varying only in brightness...
^The three lasers were different brightnesses, exposure times were the same, and all the diffraction patterns ended up the same size with identical image processing...
I think you would agree that the spikes get progressively dimmer, the further out (that's what we find with diffraction). So, if every star in that image has detectable spikes extending to the edge, there must be stars available with images that are as bright as the dimmest end of the dimmest spike. @collinsmark seems to imply saying that those 'dimmest' stars will still have spikes going out to the edge? In which case, those are not the dimmest stars available. I really don't see how anyone can argue with that logic.
I don't understand how one can say that the single photon quantisation (a quantum efficiency of 100%) is the same as the smallest step of the sensor ADC. The photon energy corresponds to the range of the frequencies involved but the digital value is what it is.
Yes and if the light level is reduced, you can lose the faintest fringe altogether.
Not necessarily. Count 10 photons from a bright source that passes through a pin hole and only 2 from a dim source. Same exposure time and the sensor is an array of single photon counters.
Suppose the 10 photons from the bright source arrive by random chance within the 0th, 3rd, 5th and 6th diffraction orders.
The 2 photons from the dim source arrive by chance within the 8th and 12th diffraction orders. The dimmer source's spikes in this case are longer than the bright source's spikes.
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/grating.html
I'll try to help you understand how that works, using examples. I'll use JWST my first example, and my own camera as a second example:
JWST:
First, you can find the specs here:
https://jwst-docs.stsci.edu/jwst-ne...detector-overview/nircam-detector-performance
Note the "Gain (e-/ADU)" and the "Quantum efficiency (QE)" in Table 1.
As you can see, JWST uses two different gain settings, one for short wavelengths and another for long.
The Quantum Efficiency (QE) is naturally dependent on the wavelength.
So let's say that were presently using JWST's F405M filter, which is a long wavelength filter with a passband at 4 microns.
Going back to Table 1, we see that
Gain: 1.82 [e-/ADU]
QE: 90% [e-/photon]We can convert that to photons by dividing the two:
[tex]\frac{1.82 \ \mathrm{[e^- /ADU]}}{0.9 \ [e^- / \mathrm{photon}]} = 2.02 \ \mathrm{photons/ADU}[/tex]
So for when JWST is using its F405M filter, it takes on average about 2 photons to trigger an ADU increment.
My Deep Sky Camera: ZWO ASI6200MM-Pro:
You can find the specs here:
https://astronomy-imaging-camera.com/product/asi6200mm-pro-mono
So, for example, if I'm using my Hydrogen-alpha (Hα) filter, which as a wavelength of 656.3 nm, we can see that the QE is about 60%.
But if I set my camera gain to 0, corresponding to around 0.8 [e-/ADU], that gives
[tex]\frac{0.8 \ \mathrm{[e^- /ADU]}}{0.6 \ [e^- / \mathrm{photon}]} = 1.33 \ \mathrm{photons/ADU}[/tex]
So with this gain setting and when using the Hα filter, it takes on average about 1.33 photons to increment an ADU.
(I like to set my camera gain to something higher for better read noise, but I'll just use a gain setting of 0 here for the example.)
Had I instead set the gain setting to around 25, which corresponds to somewhere close to 0.6 [e-/ADU], that would correspond to roughly 1 photon/ADU on average.
@collinsmark thanks for that information. It's interesting that the efficiency seems to be so high. However, isn't there something fundamental that means having gain too high will just increase the effect of shot noise wasting one bit of bit depth?
I do more or less take your point about equating a lsb to the arrival of one (or two) photons if the gain is suitable.
I don't understand how the result of such an arbitrary set of events would be relevant to the statistics of real events producing an identifiable spike pattern on a regular basis. Your instance doesn't produce a spike; it triggers a single pixel. You seem to suggest that a bright star would not be expected to produce a 'clearer' pattern of photons arriving at the sensor than a (very) dim one. I know that quantum effects / statistics of small numbers can sometimes give surprising results but normal principles of signal to noise ratio start to kick in at low numbers. Relative numbers of 'events' still tend to correlate with the continuum of analogue values that diffraction integrals give you.
That should be no surprise to anyone. That large image of many stars shows long spikes for many stars that are not actually near saturation but the fainter ones do not have identifiable spikes. When the absolute value of the spike pattern from a low intensity star falls below 1 increment then probability of it causing a hit gets less and less. I really don't see why this isn't obvious.
Here's a red diffraction pattern extending to the edge of the telescope's image circle:
Here's a blue diffraction pattern extending to the edge of the telescope's imaging circle:
Blue Channel:
Red Channel:
Here's both superimposed in the same viewing frame:
The center of the red diffraction pattern has an RGB value of 226,0,0 and the center of the blue diffraction pattern has an RGB value of 0,0,150... Which diffraction pattern is "larger?"
@sophiecentaur Yes, the gain setting does affect the noise, but it's a bit counterintuitive, and might not be what you think.
  • Firstly, it's mostly all a matter of read noise. I'll get to shot noise in a second, but read noise is affected more by the gain setting.
  • The read noise contribution is actually lower with higher gain, not the other way around. So if you want to lower your sensor's noise, and you're not at risk of saturation, increase the gain.
  • The gain value does little to nothing to the pixel detection or the electron well. It really doesn't make the sensor more "sensitive," as one might think. Rather, in most cases it merely affects the ADC operation, which is on the back-end of the pixel, not the front.
Yeah, I know, that might sound counterintuitive that increasing the gain lowers the noise. Especially if you're a typical photographer. This same thing applies to a DSLR camera. Higher ISO settings actually produce less noise, not more.
If you tell that to a photographer friend, they will yell back, "no way! When I take a photo with higher ISO it always comes back noisier!"
But what they're forgetting, is that when they increase the sensor gain, they naturally compensate by lowering the exposure: either reducing the exposure time (a.k.a., shutter speed), lower the aperture (a.k.a., f/stop), or both. Lowering the exposure reduces the number of photons accumulated, and that is what increases the noise: in the form of shot noise, since there's less signal. And for that matter, the signal to noise ratio (SNR) is reduced because, well, there's less signal. But this entire test is an apples-to-oranges comparison. Too many variables.
To make an apples-to-apples comparison, you need to lock down the exposure (f/stop and shutter speed) and compare pictures with only changing the gain setting (ISO). If you take a photo of a dim object (to avoid saturation even at high gain) and analyze the results with both gains, you'll find the one with high gain actually has the higher SNR!
Read noise vs. gain characteristics are typically nonlinear and vary quite a bit from camera model to camera model. Look at this plot showing the read noise vs. gain for my new planetary camera, ZWO ASI585MC. (Notice that it's different than the camera from my last post. These characteristics do vary quite a bit by camera model.
One thing that seems to be true in every camera I've ever seen is while although the read noise vs gain may be nonlinear, it's always decreasing monotonically: higher gain means lower read noise.
Yeah, if you're like me, this is difficult to wrap one's head around. I've created an analogy that might help.
Imagine that you keep a pile of marshmallows (representing electrons) in a silo (the well). And you have a measuring stick (the ADC) that coverts the physical height of the marshmallow pile to number (the output), representing the height.
A rabid badger (representing the source of read noise) is always grabbing the measuring stick and yanking it back and forth and all over, so it's difficult to get a steady reading off of the measuring stick.
Now here's the neat thing: You have the power change the size of the measuring stick and the rabid badger. Increasing the "gain" setting, has the effect of shrinking the measuring stick, and the badger gets smaller too, to some extent.
This however, has some ramifications:
  • By increasing the gain (and thus shrinking the measuring stick), the stick can no longer measure as high. The maximum height of the measuring stick is reduced. In other words, it's dynamic range (DR) is reduced.
  • Higher gain settings shrink the size of the rabid badger too! The smaller rabid badger doesn't do as much shaking in reference to the actual, physical height of the marshmallow stack. In other words, the important measure: the amount of shaking of the stick in units of marshmallow height, is reduced.
  • The noise of the output value (i.e., the final output number) might change with greater ADU numbers, but not relatively so. If you divide the standard deviation of the output number by the mean of the output number, you'll find the result is less when the gain setting is higher.
  • The size of the rabid badger does not necessarily shrink the same amount as the measuring stick. If you halve the size of the stick, you don't necessarily halve the size of the rabid badger, but it does get get smaller.
  • Notice that changing the gain setting really has nothing to do with the marshmallows, silo, or anything that comes before that.
Some of the increased read noise (at lower gain) might arguably be the result of higher quantization at lower gain settings (i.e., posterization). But I'm lead to believe that while posterization might play a role in explaining that, there is more to it.
Whatever the case, here's a word of advice: if you're far from saturation, and for what ever reason you don't want to or can't increase the exposure time, increase the gain instead to maximize SNR.
The colour images could be misleading because our sensitivity / perception of colours is a 'human quality. Personally, I can't see the blue fringes at all clearly on my phone. An astrophotographer, using a monochrome camera would be better placed to come to a meaningful conclusion. If the monochrome images do not follow the maths then there's something wrong, once they've been normalised. If there's a ratio, of two in the wavelengths then there should be a factor of two in the spacing (for small angles, at least).
Devin-M said:
Blue Red Channel:
Red Channel:
Assume they both go all the way to the edge but the same color. One is dimmer, which is “larger?”
Here's some proof light can diffract across an entire sensor on the JWST...
Or even 2 sensors...
Devin-M said:
which is “larger?”
Sorry, I don't get where you are coming from. If they both 'go to the edge' then the edge defines their extent. What does this demonstrate?
The theoretical curve never goes to zero.
The word "proof" implies that there is some doubt. You notice the star centre is well burnt out; there is no limit to how far out the spike could go. The (reflecting) struts supporting the reflector are the long line sources and the pattern from a line will be of the form (sin(x)/x)2 in the direction normal to the strut. Their reflecting area is pretty significant. The envelope falls off as 1/x2, which takes a lot of peaks before it starts to disappear.
Followup question. Above I’ve taken the same image of the same star and split the image into just the red light (red channel) on the left and just the blue light (blue channel) on the right. We can see the apparent position of the dimmer stars with no visible diffraction spikes are the same in both images (bottom left, top right, and the one just below the right side diffraction spike), but the points of maximum brightness of the diffraction spikes are in different positions depending on color.
Does it mean that only photons of the same color/ wavelength interfere with each other?
For example suppose I use a red monochrome laser as a point source viewed through my aperture, and note the distances of the maxima from the apparent source. Next I aim at a star (broadband) and take an exposure sufficiently long to see the same number of maxima, and look at the red channel. Will the red spots be same distance from the apparent position in both cases, even though in the star/broadband case there are additional wavelengths of light traveling through the aperature? Will the blue wavelengths for example change the apparent positions of the red interference maxima?
