Diffraction from a loud speaker
The discussion focuses on calculating the diffraction angle of sound from a loudspeaker as temperature changes. At 273 K, the diffraction angle θ is 11°. The relationship between sound velocity, temperature, and diffraction angle is established using the equations v=sqrt(γkT/m) and sinθ=λ/D. The solution involves comparing the sine of the angles at different temperatures, leading to the conclusion that the ratio of the sine of the angles is proportional to the square root of the temperature ratio.
  • Understanding of sound wave properties and behavior
  • Familiarity with the equations of state for gases
  • Knowledge of diffraction principles in wave mechanics
  • Basic grasp of temperature effects on sound velocity
  • Study the derivation of the wave equation in acoustics
  • Learn about the effects of temperature on sound speed in different mediums
  • Explore advanced diffraction theory and its applications in acoustics
  • Investigate the relationship between frequency, wavelength, and sound propagation
Acoustics engineers, physics students, and anyone interested in the principles of sound propagation and diffraction in varying environmental conditions.
pmd28
Sound exits a diffraction horn loudspeaker through a rectangular opening like a small doorway. Such a loudspeaker is mounted outside on a pole. In winter, when the temperature is 273 K, the diffraction angle θ has a value of 11°. What is the diffraction angle for the same sound on a summer day when the temperature is 307 K?
v=sqrt(\gammakT/m)
v=\lambdaf
sin\theta=\lambda/D
I can't seem to relate these equations. I know that \gammak/m is constant for both T and I also know that v increases with temperature but I don't understand how that affects lambda and frequency.
The frequency of a sound wave is determined by the frequency of vibration of the source of sound (the speaker in this case). So, changing the temperature does not change the frequency of the sound if you assume the speaker vibrates at the same frequency for both temperatures.
A good way to approach this problem is to consider the ratio \frac{sin\theta_f}{sin\theta_i} where the subscripts refer to the initial and final temperatures.
So I set that ratio equal to the ratio of vf/vi and then canceled out sqrt(\gammak/m) because it is constant in both cases therefore the ratio of Sinfθ/Siniθ is equal to sqrt(Tf)/sqrt(Ti) It was correct.
  • · Replies 19 ·
