Diffraction grating and wavelengths
11 replies · 5K views
dimpledur
diffraction grating URGENT
A spectrometer is used to analyze a light source. The screen-to-grating distance is 50.0 cm and the grating has 5000 slits/cm. Spectral lines are observed at the following angles: 12.98, 19.0, 26.7, 40.6, 42.4, 63.9 and 77.6. How many different wavelengths are present in the spectrum of this light source? FInd each of the wavelengths.
d*sinthetha =m*lambda
d=0.0002cm
The thing I am really confused about is the value "m". Which values would I use for this question, because I know m=0,+/-1,+/-2 etc..
I just don't understand which values to use.
Find the sin( theta) of all the angles.
For same d and lambda, some sin(theta) must be equal to m*sin(12.98). Find m values. Repeat the same thing for other wavelengths.
since there are 7 different angles, does that mean there will be seven different wavelengths?
I do not understand what you are trying to say here.
I know d, I do not know λ or m. How can I solve for two unknowns here? Your statement is very confusing.
No. Not necessarily. Find the sine of all angles.
I still don't really understand how to find the values of m.. For some reason this is really confusing
Will you please write down sine values of all the angles. Then I will tell you how to find m.
sin12.98=0.2246
sin19=0.3257
sin26.7=0.4493
sin40.6=0.6508
sin42.4=0.6743
sin63.9=0.8980
sin12.98=0.2246
sin19=0.3257
sin26.7=0.4493
sin40.6=0.6508
sin42.4=0.6743
sin63.9=0.8980
These four belong to the same wavelength. Because other three are multiple of 0.2246. And the remaining two belong to another wavelength.
rl.bhat said:
sin12.98=0.2246
sin19=0.3257
sin26.7=0.4493
sin40.6=0.6508
sin42.4=0.6743
sin63.9=0.8980
Alright, so there is a total of 3 different wavelengths? I think I got that.
However, when calculating the wavelengths, would sin12.98, have m=1
would sin 19 have m=1 too?
same goes for sin40.9, m=1?
Sorry for intruding here again (I am working on the same problem) but I think that 12.98/19=1, 26.7/40.6=2, 42.4/77.6=3 and 63.9=4
edit: I have checked it out, and as far as I can tell this is correct.
For last one m = 2
And for 77.6 degree, m=3.
