Diffraction with a large array of slits
  • Thread starter Thread starter Flucky
    Array Diffraction
The discussion focuses on solving a diffraction problem involving a large array of slits with equal widths and periodic displacement. For part (i), the maximum diffraction order can be determined by setting the angle θ to 90 degrees, indicating the maximum observable order. In part (ii), the minimum period a for observable diffraction must ensure that the slit width b is smaller than the distance a between slits, preventing the slits from merging into a single slit. The equations discussed highlight the relationship between slit width, separation, and the resulting diffraction patterns. Understanding these principles is crucial for accurately determining the conditions for observable diffraction.
Flucky
Hi all, exams soon and I'm stressing out over this small question. If anyone could guide me through, explaining why you're doing what you're doing that'd be beyond great. I posted this in the introductory thread but with no replies thought I should move it here (unsure of how to delete the other one).
Light of wavelength λ is incident normally on a screen with a large array of slits having
equal widths b, and periodically displaced by a distance a.
(i) Find the maximum diffraction order which can be observed using this system of slits.
(ii) Find the minimum period a for which diffraction can be observed for light with
wavelength λ = 10µm.
AFAIK the only equation relevant is asinθ = mλ
One that has cropped up is sinθ\pm1 = \pm\frac{λ}{b} , although there is no explanation next to this one so I'm not sure what it means.
Initial thoughts are to set θ = 90° as it's asking for a maximum. Past this I don't know where to go :frown:
For part (i): you are right, because the maximum angle is 90 degrees.
Part (ii): What happens when width of slit approaches the distance between slits?
From the second equation it looks like as the slit width increases the angle between maxima will decrease. Am I able to set the two equations equal to each other? If so as slit width approaches slit separation the diffraction order will go to 1.
Thanks for the reply btw.
I don't think the second equation makes any sense. All you need is the first one.
When the separation of slits approaches the slit width, the two slits become one - meaning it is a single slit diffraction. We can't let that happen, ##a## has to be bigger than the width of a slit, ##b##.
Conversely, when the width of the slit approaches the separation, the two slits become one - meaning it is a single slit diffraction. We can't let that happen, so ##b## has to be smaller than slit separation of slits, ##a##.
Thus, to answer your question - what is the smallest possible value of ##a##, in order for multiple slit diffraction to occur?
  • · Replies 34 ·
  • · Replies 20 ·
