Dimension of interaction in a QFT theory
4 replies · 2K views
nikosbak
The problem statement.
When an exercises say " the interaction in a QFT has dimensions Δ" , what does it mean?, it means the field or the Lagrangian has this mass dimension?
In this exercise I'm trying to find the classical beta function (β-function) for the assciated couling.
It sounds like they mean the power-counting dimension of the operator corresponding to the interaction in question, where the dimension of the field is determined from the kinetic term. So, in 4d for a scalar ##\phi##, the dimension of ##\phi^4## would be 4, while the dimension of ##\phi^2 (\partial \phi)^2## would be 6, etc.
Oh I see , I think i got it , but still I don't see how to compute the beta function to get to the form
$$\beta(g)=(d-\Delta)g+\mathcal{O}(g^2)$$
I really appreciate the help :)
The full exercise is :
Show that if the interaction in a QFT is has dimension Δ then there is a classical β function for the associated coupling given by ,
Discuss what happens to interactions where Δ > d or Δ < d.
Any hits or insight will do , thank you very much :D
I'll outline this, because once the concepts are put together, there really isn't a lot of work left for you to do.I will consider the case of a single field, but you should generalize the argument for multiple fields + allow for derivatives in the coupling.
Consider an interaction of the form
$$S_\text{int} = \int d^dx g_0 \Phi^r$$
and do the rescaling ##x\rightarrow \lambda x##. Under this transformation, the fields transform according to their scaling dimension, ##\delta##, namely ##\Phi\rightarrow \lambda^{-\delta}\Phi##. In fact, we will find that
$$S_\text{int} \rightarrow \int d^dx g_0 \lambda^\kappa \Phi^r,$$
for some exponent ##\kappa## that you should relate to ##d## and ##\Delta##. The theory is obviously only invariant under the scale transformation if the exponent ##\kappa## is zero for all of the terms in the action, but we can still define an effective coupling ##g(\lambda) = g_0 \lambda^\kappa##. The corresponding beta function, defined as
$$\beta_g(\lambda) = \lambda \frac{dg(\lambda)}{d\lambda},$$
can then be computed.
Ahaa I solved it . It was a lot easier that I thought !
thank for your time :)
