Dimensional analysis and frequency
The discussion focuses on using dimensional analysis to determine the relationship between frequency, mass, and spring constant in a mass measurement scenario involving astronauts. The frequency of oscillation is expressed as f = A√(k/m), where A is a dimensionless constant. By substituting known values for frequency and mass, one can calculate A²k. The example provided illustrates how to find the frequency for a different mass by using the derived relationship without needing to know A and k separately. The analysis emphasizes the importance of understanding how frequency depends on mass and spring constant.
jewilki1
dimensional analysis (Please help as soon as possible!)
The Space Shutte astronauts use a massing chair to measure their mass. The chair is attached to a spring and is free to oscillate back and forth. The frequency of the oscillation is measured and that is used to calculate the total mass m attached to the spring. If the spring constant k is measured in kg/s^2 and the chairs frequency f is .50s^-1 for a 62-kg astronaut, what is the chair's frequency for a 75-kg astronaut? The chair itself has a mass of 10.0 kg. [Hint: use dimensional analysis to find out how f depends on m and k.]
Could you please explain how to work this problem step by step, because i have no clue how to even begin, thank you.
We know that k is measured in kg/s^2, m is measured in kg, and f is measured in 1/s. I would write this as
[k]=MT^{-2}
[m]=M
[f]=T^{-1}
(M=mass, T=time)
We want to find how f depends on k and m. We do this by solving the equation
[f]=[k]^a[m]^b
for a and b. Using what we know about the units, this equation takes the form
T^{-1}=M^aT^{-2a}M^b
The solution is obviously
a=\frac{1}{2}
b=-\frac{1}{2}
so we know that
f=A\sqrt\frac{k}{m}=\sqrt\frac{A^2k}{m}
We can solve this equation for A^2k:
A^2k=mf^2
Now you can calculate A^2k using the numbers f=0.5 and m=72. Then insert the result along with m=85 into the formula for f above.
As you see, you don't need to know A and k separately. It's enough to know A^2k. If you would like to know what A is I can tell you that it's 1/(2pi), but you can't get that from dimensional analysis. You would have to solve the equation of motion (Newton's second law) to get that.
Thanks for the help.
30K
