Dimensional formula of distances in certain formulas
The discussion centers on the dimensional formula for distances in universal gravitation and moment of inertia, questioning whether L^2 is appropriate for both cases. While L^2 represents the square of distance, in the context of gravitational force, it acts as a divisor, leading to L^-2. Participants clarify that dimensional formulas do not distinguish between physical entities, as different concepts can share the same dimensions. The confusion arises from interpreting these dimensions as indicative of area rather than distance. Ultimately, the focus remains on understanding that dimensional formulas capture relationships but do not define the nature of the quantities involved.
Mathivanan
Dimensional formula for 'the square of the distance between two bodies' in universal gravitation and 'distance from the axis squared' in moment of inertia. Is L^2 is the dimensional formula for both the distances in the above two cases?
F=Gm1m2/d^2; moment of inertia=mass*distance from the axis squared
Yes, except that in the gravitational case it acts as a divisor, so becomes L-2.
Thanks. However, I have one more doubt. The dimensional formula for area is also L^2. By definitions, in the above two formulas, they represent distances rather than area. The dimensional formulas mislead me.
The dimensional formulas only capture that aspect of an expression. They don't care whether the two distances represent an actual area or have some other relationship. E.g. surface tension can be thought of as energy per unit area or force per unit length. In some cases, quite different physical entities can have the same dimension: torque and energy are both force x distance; action and angular momentum are both ML2T-1. It doesn't catch all the distinctions you'd like to make.
Thanks for your answer. I thought that distance should have dimensional formula of L, be it square of the distance or distance from the axis squared. The core concept in the definition is distance in both the formulas.
16K
  • · Replies 21 ·
  • · Replies 21 ·
