Dirac Notation - Position and Momentum
15 replies · 3K views
atomicpedals
Show that [itex]\left\langle[/itex]x|p|x'[itex]\right\rangle[/itex] = [itex]\hbar[/itex]/i [itex]\partial[/itex]/[itex]\partial[/itex]x [itex]\delta[/itex](x-x')
2. The attempt at a solution
[itex]\left\langle[/itex]x|p|x'[itex]\right\rangle[/itex] = i[itex]\hbar[/itex] [itex]\delta[/itex](x-x')/(x-x') = i[itex]\hbar[/itex] [itex]\partial[/itex]/[itex]\partial[/itex]x' [itex]\delta[/itex](x-x') = [itex]\hbar[/itex]/i [itex]\partial[/itex]/[itex]\partial[/itex]x [itex]\delta[/itex](x-x')
For the sake of formality I think I need an integral after my first equals sign which I think would be:
[itex]\int[/itex][itex]\delta[/itex](x-x') p [itex]\delta[/itex](x-x') dx'= p[itex]\int[/itex][itex]\delta[/itex](x-x') p [itex]\delta[/itex](x-x') dx'
However I'm not sure if a) it's needed, or b) if I set it up correctly. Any help would be appreciated!
Suggestion: If you're going to use LaTeX, use it for the entire expression instead of individual symbols. Fixed your post up:
atomicpedals said:
Show that [itex]\langle x|\hat{p}|x'\rangle = \frac{\hbar}{i}\frac{\partial}{\partial x}\delta(x-x')[/itex]
[tex]\langle x| \hat{p} |x' \rangle<br /> = i \hbar \,\delta(x-x')/(x-x') <br /> = i\hbar \frac{\partial}{\partial x'} \delta(x-x')<br /> = \frac{\hbar}{i} \frac{\partial}{\partial x} \delta(x-x')[/tex]
[tex]\int \delta(x-x') \hat{p} \delta(x-x')\,dx'= p\int\delta(x-x') \hat{p} \delta(x-x')\, dx'[/tex]
I actually don't follow what you're doing here at all. :wink: Try inserting a complete set:
[tex]\langle x| \hat{p} |x' \rangle = \int \langle x | \hat{p} | p\rangle\langle p |x' \rangle \,dp[/tex]
So, I was right... in that I was wrong! :)
I'll go back and work with the complete set.
I'm going to call out my own ignorance (probably related to having spent too much time with a QM book causing less clarity instead of more):
I don't see how this is the complete set. (If that question made sense, I'm on a good start.)
Shouldn't we have:
[tex]\langle x| \hat{p} |x' \rangle = \int \langle x | \hat{p} | p\rangle dp \langle p |x' \rangle \[/tex]?
Wait, does this work?
[tex]\langle x| \hat{p} |x' \rangle = \hbar /i \int \delta(x-x') \langle p |x' \rangle \,dp[/tex]
[tex]\langle x| \hat{p} |x' \rangle = ( \hbar /i ) ( d/dx ) \delta(x-x')[/tex]
What are [itex]\langle p \vert x' \rangle[/itex] and [itex]\langle x \lvert \hat{p} \vert p \rangle[/itex] equal to?
Just a side note:
Shouldn't we have:
[tex]\langle x| \hat{p} |x' \rangle = \int \langle x | \hat{p} | p\rangle dp \langle p |x' \rangle[/tex]?
They're the same thing. [itex]\mathrm{d}p[/itex] is a pure number and thus commutes with everything, in particular [itex]\langle p|x'\rangle[/itex].
The easier question to answer is what is [itex]\langle p \vert x' \rangle[/itex] equal to
[itex]\langle p \vert x' \rangle = 1/ \sqrt{2 \pi \hbar} exp( (i/ \hbar) p x')[/itex]
The more important question is then what does [itex]\langle x \lvert \hat{p} \vert p \rangle[/itex] equal, because I don't think I know anymore! Except to say that it has matrix elements (and I'm not sure what those are).
Surely you must know what [itex]\hat{p}\vert p\rangle[/itex] is equal to.
Well my first gut reply is that
[itex]\hat{p}\vert p\rangle = p\vert p\rangle[/itex]
Right, so [itex]\langle x | \hat{p} | p \rangle = \langle x | p | p \rangle = p\langle x | p \rangle[/itex].
Ah right! Ok, so what's the mathematical reasoning that gets me from [itex]\langle x| \hat{p} |x' \rangle[/itex] to [itex]\int \langle x | \hat{p} | p\rangle\langle p |x' \rangle \,dp[/itex] ? I'm really trying to understand the basic underpinnings of what's going on.
I'm considerably more comfortable with the original problem. Now I've got a follow up (thanks to yesterday's class). We have
If [itex]p = i / (\hbar) d/dx[/itex] and [itex]\langle x | p \rangle = 1 / ( \sqrt{2 \pi \hbar} ) exp[ (i / \hbar) p x) ][/itex] How do I go about determining matrix elements? Is it as simple as the product of p and [itex]\langle x | p \rangle[/itex] and then taking x = 0,1,2,...?
No. I don't understand what you're trying to do.
I would like to determine matrix elements for [itex]\langle x | \hat{p} | p \rangle[/itex].
I think you're confusing the operator [itex]\hat{p}[/itex] with the eigenvalue [itex]p[/itex] of the momentum eigenstate [itex]\vert p \rangle[/itex].
