Dirac Wave Function: Schrodinger Equation Coupling
7 replies · 2K views
jamie.j1989
Hi, is the wave function that couples to the Dirac equation the same as that which couples to the Schrödinger equation? Thanks.
No, it's different, the biggest difference is that the Dirac equation has a bispinor as a solution. But generally the Dirac wavefunctions follow relativistic transformation rules, the Schroedinger ones are Galileian.
In addition, it has a completely different physical meaning. It cannot be interpreted easily as a "wave function" like in nonrelativistic physics. The reason is that at relativistic energies, you always can create and destroy particles in scattering processes. The Dirac equations solutions are Dirac-spinor fields. They are best interpreted in their quantized form, leading to relativistic quantum-field theory, because this is the most elegant way to describe particle creation and destruction or, more generally, many-body systems in quantum theory.
Yes. Though I didn't want to stress that because single-particle relativistic QM, inconsistent as it is in the fundamental interactions context, has consequences like Klein's paradox that actually show up in solid state physics iirc.
I don't quite understand why if particles can be created and destroyed in scattering processes at relativistic energies we can't easily interpret it as a wave function? Also by scattering processes are you referring to particle collisions?
If particle numbers are not fixed you have a Fock Space and the QFT formalism.
Its inevitable when you combine it with relativity that particle numbers are not fixed - see for example section 8.3 of:
https://www.amazon.com/dp/019969933X/?tag=pfamazon01-20
Thanks
Bill
